2003 clk 430 hydraulic fluid?
Old 09-03-2015, 09:16 PM
JackRobinson's Avatar
2003 clk 430
Hi All, Having problems with the top not going up or down. I'll post more of symptoms later. For now I want to check the hydraulic fluid and can't find the reservoir. Looking under the hood and can't find it? Hopefully just low on fluid and I read here it will pump all day and won't work if it's low.
Again it's a 2003 with the manual front top latch.
Thanks, Jack
Old 09-04-2015, 01:17 AM
Yidney's Avatar
2008 CLK550 Cab
If you have a 430, then you have a W208 and should post in that forum. But I feel certain your fluid reservoir is behind a side panel in the trunk like on the W209.
Old 09-04-2015, 10:24 AM
2003 clk 430
Thanks. Any idea what side?
Jack
Old 09-05-2015, 10:28 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Ont he W208, the pump sits behind the back seat. You access it from inside the trunk, but first you must remove the metal panel that covers it.
Old 09-07-2015, 09:16 PM
2003 clk 430
Thanks for the help. I found it behind some felt cutouts. It's full, darn it but I'm narrowing it down thanks to your help and others.
Thanks again, Jack
Old 06-21-2017, 05:05 PM
kenlake's Avatar
clk 430 convertible
what fluids are good
Old 06-22-2017, 09:48 AM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Here are the approved fluids:
http://bevo.mercedes-benz.com/bevolisten/343.0_en.html
I also understand that Pentosin CHF 11s can be used. It is normally used for power steering fluid and often available on the shelf at retail auto parts stores. It's green, and stinks (like burned diesel fuel), so if you have a leak, it's harder to clean up.
Quick Reply: 2003 clk 430 hydraulic fluid?
