Window rubber lubrication
Old 09-13-2015, 03:56 PM
mrwhattie's Avatar
2005 ML 270 CDI, 2004 E270 CDI, 2006 CLK55 AMG
Do any of you guys with CLK soft top / convertables lubricate the window rubbers. If you do, what product do you use? That movement of the windows when ever the doors are opened or closed seems to be a high friction area.
Old 09-14-2015, 06:52 PM
eteller's Avatar
2009 CLK 350
I use 1z (einzett) Gummi Flege which is a rubber conditoner on all my door seals, you can find it on Amazon. Another trick I learned from having a GM with t-tops is silicone diver grease also works, also on Amazon. Just don't use Vaseline as that will eventually melt your seals.
Old 09-15-2015, 04:05 PM
mrwhattie's Avatar
Thanks for the reply eteller, I'll have a look out for those.
Old 09-16-2015, 12:25 AM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
MBZ has an excellent lubricant for the soft top seals: A0009893360
Old 09-16-2015, 01:06 PM
mrwhattie's Avatar
Thanks Rudeney, I'm going to check if my dealer has any.
Old 09-16-2015, 01:38 PM
megacrazy's Avatar
CLK55 W209, CL63 W216
Tried all the products mentioned in this thread. The OEM one works the best. You can also get it on eBay cheaper in larger quantities without the MB branding.
Quick Reply: Window rubber lubrication
