HI everyone I am new to fitment issues
And I guess I should ask this as well - is the center bore on your wheels the same size as the hub - 66.6mm or whatever it is? If not, then you need inserts as well as hub centric spacers - or else hub centric spacers where the little shelf is machined to match whatever diameter center bore you have.
Good questions ... i well go in the laboratory and do some closer examination with your tips in mind i really appreciate your help yidney
hey mr jones
Are u streching tires in the front and rear?
I am trying to figure out what size tires to buy but for some reason I can't find a single manufacturer that makes the tires for the rear end for the front I keep coming up with two different brands the tire sizes I was thinking about going with are 225/30/r20 front and 275/25 rear
Its so confusing.
Its so confusing.
these are some pics from my previous and daily setup i will be putting back on soon. the size for those wheels is 19x9.5+35 all around. i used 15mm spacers up front to clear the wheel from hitting the strut and i used 30mm for the rear.
19x9.5+20 225/35/19 front
19x9.5+05 235/35/19 rear
90mm extended wheel studs
1 Post
W209, E46 M3 (dead), S54 swapped E46 Touring
Its so confusing.
Its so confusing.
I used that 1010tires calculator and that was the only specs that can stay within the 3% speed variance so i dont throw my speedo off to much or the wheel speed sensors for the traction control and abs. My other question.
Are Achilles good tires? They seem to have the sizes i am looking for.
