2009 Coupe leaking
I can't be sure, but I though the channel was actually attached to the glass. But is it "pushed down" farther in the places it does not snap in than it where it does snap in?
I'm not surprised you have leak only on one side. The water still had to find an opening under there. And the original glass brand is Sekurit, so yeah, yours is new.
Alright, I took the plastic windshield cowl cover off and I did see what's supposed to be that channel. But whoever installed the windshield might have screwed up, as there is a step down from the windshield to the channel, and the web on the plastic piece doesn't seem to be long enough to reach the channel.
I pried the channel open some more as suggested above by Yidney. But I could only get a 10 inch section to snap into the channel. The remainder is actually worse than before.
I'll take it back off to see if I can get some more opening and try again.
Sorry I didn't get any pics today, will do that on the next try as well.
Yidney, mine was closed shut, no gap at all to lock the plastic piece in place.
Here are some pics I took yesterday after I removed everything again.
This is the drivers side, where it actually snapped into place. See how the aluminum piece is inline with the windshield?
Now this is the other side, and the aluminum piece is hanging down, the arrow from the plastic piece doesn't even reach down far enough the hit the channel.
Whoever installed the new windshield clearly didn't know what that aluminum channel was for.
I'll put everything back together and wait for the next rain. Maybe cleaning the drain tubes was all that was needed.
If not, I thing I need to get the windshield reinstalled.
Hard to tell for sure but it almost looks like it's not so much bent down as it is not all the way on the glass at that end - like it's rolled down. The bad news is that they may not be able to reinstall the glass. If you look close on the sides you'll see the little connections for the antennas. Those get set in the adhesive due to their locations and will be ripped off as the glass is lifted. When I had mine installed they installed it off center so that the black shade bands on the sides were very uneven, and I made them fix it. They had to put in a whole new glass.
#32
Just wanted to update this thread, as I feel too many people after asking for help don't come back reporting what actually fixed their issues.
After checking into windshield replacement cost, and reading about issues arising while just reinstalling the windshield (antennas, light/rain sensors,...), I decided to not go that route.
I bought some black silicone and applied a small bead right under the plastic piece (part #80 in the above schematic), wedged it together and let it dry for two days.
Since then I've been to the car wash and driven in the rain with no issues.
Looks like tomorrow will be a rainy day, so the car will be sitting in the rain while I'm at work. That should clear everything up
UPDATE:
The car has been sitting in the rain all day yesterday and it's still dry inside. I'm happy!
UPDATE:
#34
Update after two month:
Unfortunately the sealer didn't hold up and I notice gaps between the wind shield and the plastic cowl piece.
So far the car is still dry inside, but I'll be sure to check after the next big downpour.
Maybe I get lucky and the clogged drains were the problem to start with...
#35
2005 CLK500
Cowl hood cover
Thanks for this thread. The driver side of the cowl cover has popped out of its slot/place. **praises to yidney for the experience, knowledge and writeup***. I am at a loss(my flaw)in figuring out the "aluminum strip" from the pics. Can you shed any light there? And second, how to get the wipers of after removing the nut/bolt?
Thank you.
Thank you.
#36
Thank you.
Thank you.
If it just popped up recently and was fine before, that's all it might need.
To remove the wipers I just one of those small pullers to get them off:
jwb007 (07-01-2017)
#37
2005 CLK500
Cowl hood cover
Update/ The strip at the bottom of the windshield was partially of. I had to adhesive back to the glass. That was reason why half of the cowl cover had popped out, and wouldn't pop back in place. Hoping that the adhesive stay bonded for a long while. I didn't take any pic, my apology.
Thanks to all who contributed to this tread. I had been living with this issue for sometime. I didn't know the actual name of the cover(cowl). Thanks to this forum for all the shared experiences.
We should take this concept and apply it to our everyday interaction with everyone. For everyone of do need each other, more than we can admit to.
