Removing center console
Old 02-08-2016, 05:08 PM
clk350Driver's Avatar
2007 clk350 w209
I have my stereo\dash ripped apart. But I now need access to the compartment \right arm rest\center console.
How do i take it apart? The idea is to route some usb plugs in there for easy access. thanks a ton!
Old 02-10-2016, 01:55 PM
sailorben's Avatar
CLK W209
Take the gear shifter surround off, and the trim panel around the shifter, then route the cables from the back of the head unit, and down to the bottom back corner of the space you've just found, there is a hole through to the centre console bit; behind the hidden coin tray.
Quick Reply: Removing center console
