Failed Washer fluid pump. OEM vs. Aftermarket
Old 04-28-2016, 10:31 PM
merceBENZ's Avatar
2006 Mercedes-Benz CLK500 Convertible
Red face Failed Washer fluid pump. OEM vs. Aftermarket
I assume my pump is dead since there is no liquid comes out and tank is full. My little research showed that this is quite common problem.
I found bunch of different pumps on eBay. Starting at $7 for aftermarket and ending $40 for OEM.
Can anyone advise on that one? Does it make sense to by OEM with tends to fail? Any suggestion on aftermarket one?
Any input would be highly appreciated.
Old 04-29-2016, 05:37 AM
sailorben's Avatar
CLK W209
I just got a cheap £10 one from eBay, been fine for 6 months, spray just as powerful.
Old 04-29-2016, 08:09 AM
merceBENZ's Avatar
Why did you go cheap route?
Old 04-29-2016, 08:49 AM
sailorben's Avatar
CLK W209
I've had used similar after markets for the other cars we have had and they've been fine. But ultimately, I was 17 at the time, and needed to try and save the money, so I decided to take the risk and go the cheap route on this particular part. It's a fairly basic part with no real load on it
Old 04-29-2016, 08:57 AM
merceBENZ's Avatar
Maybe I should give a try. OEM failed anyway
Old 05-01-2016, 11:00 AM
Hoserbenzo's Avatar
08 CLK 350 sport, 11 BMW 328i, 99 Dodge Ram 1500 4x4, 06 Suzuki DRZ400SM
Make sure u press the button all the way. When I first got my car, I thought my pump was broke. It was full of fluid like yours. I finally figured out that you need to press all the way in. If you press it partially, it will make a sound but no water. Try pressing all the way.
Old 05-01-2016, 11:03 AM
merceBENZ's Avatar
Thank you for tip. I will give it a one more try today.
Old 05-01-2016, 12:05 PM
merceBENZ's Avatar
No, it doesn't work.
Old 05-01-2016, 03:49 PM
mis3's Avatar
2004 CLK320
My water pump malfunctioned back in Oct-2011. I had no choice but to have it serviced in the dealership.
The cost of the water pump was $327CAN, thermostat was $45 and labour was 2.1 hours. With the other misc charges and tax, the total invoice was $715CAN. I did get 15% discount on parts.
For engine parts, I insist on OE part (MB parts, not even OEM). I am not a DIY person so I cannot afford to pay for the labour again.
Old 05-01-2016, 03:52 PM
merceBENZ's Avatar
OEM - Original Equipment Manufacturer. In this case MB. Same thing.
Old 05-01-2016, 04:35 PM
mis3's Avatar
2004 CLK320
Problem is from what I can see, the definition of OEM in some online stores are misleading. For example, Mann supplies air filters to MB but if they sell Mann brake pads (they don't but just as an example), they are still considered OEM.
I do find the original suppliers of some MB parts (Mann is one example) here but not for every parts.
Old 05-01-2016, 10:00 PM
merceBENZ's Avatar
In this case scenario MB puts their label on it. But I don't know to much of it. I bought genuine filters from MB and there were no word from Mann. Maybe it is second choice. But OEM was always standing for original parts next to genuine. OE is aftermarket.
Everything from my experience and observation of others.
Old 05-01-2016, 10:07 PM
mis3's Avatar
2004 CLK320
i learnt from this forum thatm Mann are the supplier of MB air filters and oil filters. i have been using them for a few years with no issues, just make sure the oil filter is made of fleece. Mann filters are probably the only non-MB engine parts I use.
Check this out:
http://www.autohausaz.com/pn/1120940604
http://www.autohausaz.com/pn/HU7185X
Old 05-01-2016, 10:23 PM
merceBENZ's Avatar
Last year I bought engine filters with MB stuff on it in MB package. I saw Mann filters and passed them.
Old 05-01-2016, 10:55 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
"Genuine" parts will be be labeled "Mercedes-Benz" and will have the three-pointed-star logo. MBZ subcontracts the manufacturing for many of its parts. Those subcontractors are allowed to resell those parts themselves, but they are NOT allowed to mark them as "Mercedes-Benz" or use the star logo. Examples include Mann, who makes the oil and air filters for MBZ, but also sells them under their own OEM label. Lemfoerder makes the front control arms for the suspension for MBZ, but also sells them under their own OEM label. Now, would I buy Mann control arms or Lemfoerder filters? Probably not. Each of these companies has a specialty. I would buy what the specialize in making.
Old 05-01-2016, 11:02 PM
merceBENZ's Avatar
I got your point. So I guess I wrong. But I still consider OEM to be MB.
Old 05-01-2016, 11:08 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Oh, I do, too! It's just that they can't put The Star on the parts. And BTW, this is not just an MBZ thing - this is the case all over the world with most every major manufacturer. An not just automobiles.
Old 05-01-2016, 11:44 PM
mis3's Avatar
2004 CLK320
Exactly my point. Once a manufacturer supplies even one part to MB, the online store would identify this manufacturer as OEM no matter which parts they are selling.
If you know the supplier of a given part, to buy OEM parts are certainly OK. In this case, I would not be concerned to buy Lemfoerder control arms anytime.
Old 05-02-2016, 09:30 AM
merceBENZ's Avatar
Well, now I now.
Btw, I ordered continental VDO pump. $22 shipped. Figured it is worth a try. Had good reviews and made in Europe.
Old 05-02-2016, 11:10 AM
Coffeebean's Avatar
C63 AMG
Stick OEM, anything else will be cheaper but it's a false economy. OEM parts longevity is always better.
Old 05-02-2016, 11:40 AM
merceBENZ's Avatar
OEM failed me. VDO is very big name. As long as it is not made in China I will be fine.
Old 05-02-2016, 11:56 AM
omega48er's Avatar
2009 clk-350 (Black) AMG, 2009 clk-550 (Pewter) AMG
at around 40 bucks i would go Mercedes. My CLK550 is in the shop for a few things including this.
Motor trans mounts, outter tie rods, keyless (driver side) .
I would DIY most of it but since i have an aftermarket warranty ima let them deal with this.
A shame since i only have 30 or 31k miles on mine. Its typical for these mounts to last 20-30k miles... MY clk350 had them changed at 27k miles.
Still love the car and cant see myself parting with it any time soon.
Old 05-02-2016, 12:05 PM
merceBENZ's Avatar
I believe that continental vdo is their supplier. Mann situation.
Old 05-02-2016, 03:16 PM
Martin_F's Avatar
2009 CLK 350
OEM failed you? So what after 10 years? Everything breaks eventually.
If you buy another OEM, you can assume it'll last another 10 years. Is that worth $40?
Who knows how long the cheaper pumps last...
Old 05-02-2016, 03:34 PM
merceBENZ's Avatar
That is a true as well. But still not long enough to fail. This is not everyday use pump.
Quick Reply: Failed Washer fluid pump. OEM vs. Aftermarket
