Battery
Old 06-23-2016, 08:37 AM
Ptrigg17's Avatar
2009 CLK550 convertible, 2012 ,,E550 Cabrio, 2012 Audi Q5
Battery
About 1 month ago I posted that 2 unrelated codes popped up 2004 and 0025. It was suggested that a weak battery could be the cause . I charged the battery and the codes dropped off in a few start / stop cycles. Yesterday after a month of daily use the same 2 codes popped up. I checked the battery and got the following readings after sitting overnight in 70 degree garage, voltage 12.6 percent charge 85 . It is a Mercedes battery with a date of 3/14. Any thoughts or advice will be appreciated. The car continues to drive perfectly.
Old 06-23-2016, 11:04 AM
JimVonBaden's Avatar
2005 CLK500
First, you bought an old battery?
Second, your voltages are a bit low. Do you dive a lot of short distances?
Old 06-23-2016, 11:55 AM
Ptrigg17's Avatar
Bought the car last January with that battery, yes I drive short distances . Charged battery , 3 start/ stop cycles light went out. Not sure t if I need to change battery or charge it once a month
Old 06-23-2016, 01:04 PM
2005 CLK500
Yeah, sounds like the battery is getting weak. Either put it on a charger once a week, or take a 30 minute drive once a week. These cars seem to be sensitive to weak batteries/charging systems.
Old 06-23-2016, 01:47 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
Or don't risk it and buy a new battery.
Old 06-23-2016, 05:32 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
The last genuine MBZ battery I had crapped out after two years. They used to be better than that. I've switched to using the Advance Auto Platinum AGM - I've been very happy with them.
Old 06-24-2016, 08:11 AM
2005 CLK500
That is what I use on my motorcycles as well. Seems quality in a world of crappy batteries lately.
Quick Reply: Battery
