Staying water on longitudinal (under brake pump)
Old 06-26-2016, 05:40 AM
cutin's Avatar
CLK240 w209 '02 Elegance
When I lifted my CLK I observed water dripping from the left front fender. I located the source and this is longitudinal (under brake pump). I wondering is there any bloked up drain hole or something and where is? That water comes from the hood.
Old 06-26-2016, 11:20 AM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
This area under the hood is not water-tight, but with the seals around it properly mating to the underside of the hood, and the water collector drains in place and clear, it should not get wet except in the most horrible weather. Check these seals and also make sure the drains tubes are clear and in place.
Quick Reply: Staying water on longitudinal (under brake pump)
