Unable to Unlock Glovebox
Old 08-19-2016, 07:52 AM
rudz1's Avatar
CLK 320 Convertible
Hello everyone and thank you in advance for your support.
I have a clk 320 convertible 2004 and the glovebox is stuck, i'm unable to unlock it using the key nor manually.
If anyone has a solution for this problem i would highly appreciate your help.
Thanks again.
Old 08-19-2016, 09:36 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Sometimes the contents of the glove box push on it and it won't unlatch. Try pushing up on the lid while pulling the handle to see if that's the issue.
Old 08-20-2016, 05:19 AM
ALFAitalia's Avatar
Alfa 159
Key? Mine does boot have a keyhole.
Old 09-18-2016, 08:36 AM
rudz1's Avatar
CLK 320 Convertible
Thank you for your submission and sorry for the late reply. But this method has not worked for me unfortunately.
rudz1's Avatar
CLK 320 Convertible
Thank you for your submission and sorry for the late reply. But my clk 320 2004 does not have a keyhole :/
Old 12-20-2016, 06:51 PM
m1mmmm's Avatar
2006 CLK350 Cabriolet (A209)
Hi Rudz1 - I have owned my CLK for 10 years and just the other day discovered my glovebox was locked and would not open. I searched here and found out I have to unlock my car from the key fob or the glovebox will remain locked. If you are sitting in the car and push the unlock button on the dash it would not unlock the glove box. With that info I went outside and unlocked the car using the "unlock" button on the key and my glovebox opened fine when I pulled handle. I can't believe I've had the car this long and just discovered this fact. Hope this helps.
Quick Reply: Unable to Unlock Glovebox
