Anyone use Race ramps?
Old 08-19-2016, 08:48 AM
Reanimation's Avatar
270 cdi w209
Anyone using race ramps I've been using some crappy steel ramps that slide when I try to drive up them, so I'm thinking to replace them with Plastic race ramps, Are they any good?
Old 08-19-2016, 09:40 AM
megacrazy's Avatar
CLK55 W209, CL63 W216
Yuuuuuup. Pretty much a must if you have a lowered car. They're also light as hell and easy to store. No complaints so far...except for the price. 400$ for a set of ramps is a little.....mmmmyeah.
Old 08-19-2016, 09:10 PM
sailorben's Avatar
CLK W209
Have you tried putting a fairly chunky block of wood in between the ramp and the tyre? When I do it, it gets the tyre up and onto the ramp, without trying to push the ramp away.
Reanimation (08-20-2016)
Old 08-19-2016, 09:12 PM
sailorben's Avatar
CLK W209
Or try wrapping a rope around th slats on the ramp. Gives the tyre better grip. Also have put a bit of wood on the bottom of the ramp itself that gives the base more friction.
Old 08-19-2016, 09:55 PM
jcjmw's Avatar
2005 E55 Wagon
I have had my race ramps for several years now. It's a must have if you work one the car. After you get it, use it and then store it, you will realize it was money very well spent.
Old 08-20-2016, 05:24 AM
ALFAitalia's Avatar
Alfa 159
I stand my ramps on a pair of old rubber car mats....they never get pushed away by the tyres that way...even on my worn shiny concrete drive!
Fatz (08-20-2016)
Old 08-20-2016, 12:28 PM
Patton001's Avatar
2006 CLK350
You might check out Rhino Ramps. I have been using mine for 20+ years and they are great. Very lightweight and tough. Great for lowered cars. They have a rubber puck on the leading edge so they don't scoot when you drive up onto them assuming the surface they are on is clean. Also cost less than Race Ramps I believe.
Old 08-20-2016, 12:45 PM
270 cdi w209
These are the Rhino ramps I'm looking at,
http://www.ebay.co.uk/itm/HEAVY-DUTY...0AAOSwBLlVba4i
Do they raise the car enough? Its mainly for oil/fluid servicing.
Old 08-20-2016, 12:47 PM
270 cdi w209
$400 what make are they? I'm looking at around $100 for a pair.
Old 08-22-2016, 04:55 PM
megacrazy's Avatar
100 for a pair???
https://www.amazon.com/Race-Ramps-RR...Ramp+-+2+Piece
https://www.amazon.com/Race-Ramps-RR...Ramps+extender
About 350$.
Old 08-22-2016, 09:47 PM
clydem's Avatar
2005 320CLK Cab
I have the steel ramps. But rather than drive to them, I push them flush to the tires & then drive up them. No problems.
Old 08-23-2016, 01:24 AM
Fatz's Avatar
2008 clk550 - Navigator - Frontier
I've found the $100 variety to be too steep (they are not very long) to easily get a lowered car on and off of them, particularly if your on a smooth garage floor. I have a pair I got from Advance Auto, I think. I only use them when I need to work under the car from the rear. They are molded in a single piece, making it difficult to get under the car from the side if used to raise the front.
I plan to buy a pair like those referenced by megacrazy sometime in the near future.
Old 08-27-2016, 02:40 PM
MarcusF's Avatar
2002 CLK430
You can make your own stands and use a floor jack to set the car on them. I made the stands below. This is an 8-inch lift and handles most tasks (Motor mounts, trans mounts, radiator, etc.). I have a second set of stands that I can put on top of these if I need to do something that requires a lot of space. The second set adds 6 inches, bringing the lift to 14-inches. This is very safe and the car is as stable as is it were parked, because it is. The wood costs were around $20 at a home improvement store. 2x4's make the base with 2x6's under the tires. A box of 2-inch wood screws was used to hold it together.
Reanimation (08-28-2016)
Old 08-27-2016, 10:42 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Don't forget that most MBZ's have center jack points. With an appropriate low-profile jack, you can lift both front wheels or both rear wheels with one operation. Then slip in jack stands or wheel supports as needed.
http://benzbits.com/w209/JackPoints.pdf
Old 08-31-2016, 08:44 AM
eteller's Avatar
2009 CLK 350
That's called cribbage BTW. I hate climbing under a car on stands so I'm going this route.
Quick Reply: Anyone use Race ramps?
