need advise from mechanic please
so i finally got the rite codes , i just have no idea were i should start or what i should do or look at first. id greatly appreciate it if you see this and you now some thing to help thanks!
p203e -no CAN message from instrument cluster or message faulty. communication fault/see also CAN status in freeze frame data (P0600)
p207D -no or incorrect CAN message from control unit N73 (EIS) {EZS} control unit) communication fault/see also CAN status in freeze frame data (P1999)
p2031 -no or incorrect CAN message from control unit N80 (steering column module) Communication fault/see also CAN status freeze frame data (P1999)
p2004 -b2/5 (hot film mass air flow sensor) :Check sensor signal and voltage (P0101
p2042 -SAFETY Fuel SHUTOFF DETECTION (P1999)
How do i go about this ? please have no knowledge in mechanic what so ever. thanks !
so im guessing the p2004 is a broken throttle flap? because i have a new maf sensor bosch so i know its not that
