Visit Workshop Light - Battery
2002 W209 240
Hi guys
I have a visit workshop light on my wife's CLK.
The external lights and the dash lights go out for a few seconds and come back on and now the doors are unlocking and locking all by themselves as you are driving and the seat belt assists are extending.
I have replaced to battery - light still on.
I was told it could be the voltage regulator on the alternator
- new voltage regulator.
I have replaced the alternator.
I have checked the voltage
- 12.9v engine off
- 14.4v engine on
- 13.5v with all lights on, air con on, front and rear window heaters on.
So I assume the charging system is working.
What do I need to check/change to get rid of the Visit Workshop light?
Cheers
Sipstrassi.
- 12.9v engine off
- 14.4v engine on
Cheers
Sipstrassi.
Hey Biff, you still have not diagnosed the fault---spend some money on the diagnostics before you go crazy and waste all that money on parts!!
PS: Understand your limitations!!
2002 W209 240
Had it hooked up to a diagnostic machine.
Says SAMS registering low voltage.
Also had the old alternator bench tested and it is not showing any faults and give a good voltage.
thin it may be off to a Independent Merc Mechainc to sort.
Yes, and depending upon the steering wheel location the rear SAM is on the same side as the steering wheel---simply pull the cover back and view, however without the tools what are you going to do look at it!!
Based on your first post, it would seem that you did all you could to improve the low voltage reporting(although I think you did not have to make all the changes you did)----------after all said and done when you clear all the faults---do the faults return---if the do then my guess is that you have a faulty front drivers side SAM---why because that is where the voltage is sensed and reported when low to the IC and others---remember the SAM is a place for fuses and relays to be activated but also houses a group of microprocessors that preforms the voltage switching!! one is not functioning!!
MBworld Guru
MBworld Guru
I'd clear the faults and see if they return. 13.6v is a little low. It should be 14v+ even with "all" accessories on and the engine running, though that's not really low enough to trigger faults. It's possible you had a bad battery or alternator that damaged a SAM. They are a bit fragile when it comes to voltage fluctuations.
