P0410 and P2047 error codes
MBworld Guru
This code is:
2047 - [1] Secondary air injection: malfunction (function chain) , Air flow is too low. [P0410]
The Kompressor engine uses the output from the supercharger instead of a secondary electric pump. There is a control valve that is vacuum actuated. I'd check for vacuum leaks.
clk200 w209 2004 kompressor
[QUOTE=Rudeney;6921643]This code is:
The Kompressor engine uses the output from the supercharger instead of a secondary electric pump. There is a control valve that is vacuum actuated. I'd check for vacuum leaks.[/QUOTE
Do you know where this control valve is located ?do you have a picture ? How will i check for vacum leaks ?
MBworld Guru
I can't find a photo, but I think it's on the pressure side of the duct coming out of the supercharger. I seem to recall this being covered in the W203 forum - search those codes there and see if someone has photos.
i have checked but no post . is there another way to help . maybe a code for the valve or where is it exacly on the engine
Wow... Rudeny you are a good guy. Whit a crap op like that I would have just ignored it.
I have a car that's broken tell me how to fix it.
