Icarsoft i980..
Old 09-24-2016, 03:25 PM
daking1959's Avatar
2009 CLK 350
Icarsoft i980..
Just received a Icarsoft i980.Got this for a $130.
First impression is this is a well built scanner..
simple to use.
the only code that it reported is B1022..
cant find this code anywhere.
any guidance would be helpful
dk
Old 09-24-2016, 09:49 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Does it not tell you which system it scanned this from? Looking through various tables of DTCs, the only one I found with a B1022 is the SRS system. That indicates "faulty coding".
Old 09-25-2016, 06:23 PM
daking1959's Avatar
2009 CLK 350
just checked again..
It now shows 2 codes C1151, which is 58d short circuit..
the other is B1450 air sensor..no idea what the fix is
any ideas?
Old 09-25-2016, 09:59 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
B1450 is an ACC system code. It indicates a problem with the outside air quality sensor, which is located under the hood, on the right side of the cabin air intake duct. C1151 is an ESP code, and indicates an inplausible value from the lateral acceleration sensor.
Are you have nay particular problems you are trying to diagnose, or are you just scanning for any stored codes? It't not uncommon to get occasional "burps" that will cause intermittent errors. It's best to just clear them, and check later if you have any particular issues.
Old 09-26-2016, 10:57 AM
daking1959's Avatar
2009 CLK 350
many thanks..
No problems..car runs like a top..20k miles on the clock.
Good advice Rudeney. I will clear the codes.
your SL looks great
Old 01-05-2022, 03:47 PM
Khawajas78600's Avatar
Clk200 cabriolet 2004 w209
Clk200 cabriolet 2004 p0410 late gear change
Hi every one my mercedes clk is lpg I have a code p0410 also rich fuel fuel it changes gears late some times I have used many cleaners and have had the gear box serviced just can't find the problem can anyone help I have a diagnostic icarsoft 1980
Quick Reply: Icarsoft i980..
