Ashtray light
Old 09-30-2016, 02:45 PM
mike1slonina's Avatar
2006 Mercedes CLK500 W209 chassis
Ashtray light
2006 CLK500 Coupe. How is the center console removed to access burnt ashtray bulb? Viedo?
Old 09-30-2016, 10:29 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
The wood (or metal) panel on the center console is held in place with spring clips. You can open the ashtray and pull up firmly on the leading edge to remove it. You actually don't need to fully remove it to access the ashtray module - just lift it up so you can access the two plastic clips on the ashtray module. Unclip them and the ashtray slides out of the console.
Search for threads about removing the radio and you'll find video or other instructions on this.
mike1slonina (10-01-2016)
Old 10-01-2016, 05:41 AM
irokdastar's Avatar
2004 CLK 500
Mine is burned too. What size bulb is it ?
Old 10-03-2016, 06:28 AM
DanielFD's Avatar
2007 BMW 550i
I cant remember what size it is but i do remember mine wasn't burnt. The metal contacts had developed some corrosion and weren't passing current. Some conductive grease solved mine, didn't change the bulb.
Old 10-03-2016, 01:06 PM
eteller's Avatar
2009 CLK 350
Huh, I don't ever recall seeing a light. Wonder if mine is bad too?
Old 10-04-2016, 04:29 AM
DanielFD's Avatar
2007 BMW 550i
yup. all the clks have an ashtray light. It lights up the lighter itself and there is an opening in the ashtray that lets light into the ashtray itself too. Also i Think all US CLKs have an ambient light in the mirror which is most likely burnt out. If you look at the bottom of the interior mirror and see a hole and no light then thats burnt out too. I replaced that bulb and fixed the ashtray bulb in my clk.
Old 10-04-2016, 09:09 AM
eteller's Avatar
2009 CLK 350
Hmm, I have a project this evening. I'm assuming said mirror light would come on when you open a door?
Old 10-04-2016, 09:17 AM
DanielFD's Avatar
2007 BMW 550i
Nope, its an ambient light its on whenever ignition is on. Gives a nice amber glow to the interior. Stock its an ancient filament bulb with a yellow condom. You could replace it with another filament bulb just be careful removing the yellow condom from the old bulb as it rips easily, that way you can reinstall it on the new bulb. You could upgrade it to an amber led but make sure its 12v led or ull burn the led bulb, also leds are polarity sensitive so if it doesnt work flip it! Enjoy!
eteller (10-04-2016)
Old 10-04-2016, 10:28 AM
eteller's Avatar
2009 CLK 350
So I'm pretty positive mine is burnt out then, this bulb would be near the garage door opener buttons? How does one access the bulb? Is there a cover or do you seperate the mirror halves?
Old 10-04-2016, 10:44 AM
DanielFD's Avatar
2007 BMW 550i
Yupp seperate the 2 halves! Start from the middle there are a couple clips all around the mirror. Removing mirror is a ***** though. Remove the dome light and disconnect the wires for the mirror then if i remember correcty you pull down the mirror or pull it forward i cant remember exactly i used some guides from the w203 boys as its the same system there.
I do remember i ruined the contacts for the bulb so i used power from the door opener so have a tester around so you test which wire has 12v power that you can tap into, ground would be the black or brown wire next to the positive 12v.
Old 10-05-2016, 03:00 PM
eteller's Avatar
2009 CLK 350
So I was stuck in traffic today and I found out the mirror light is working. The ashtray light was off but so were the lights.
Old 10-05-2016, 07:03 PM
irokdastar's Avatar
2004 CLK 500
anyone know the bulb size fir ashtray?
Old 10-05-2016, 11:52 PM
NewShockerGuy's Avatar
20' RCF, 18' NX, 09' E350, 07' Solara, 05' STi, 01' Ranger
The ash tray bulb is a 74 bulb. Any autoparts store will have it. Or change it to an LED.
Keep in mind however if you change it to an LED it will most likely be nice white while the rest of the dash is that horrible amber color that we have. (still don't understand why MB didn't make everything nice white like the gauge cluster)
I replaced mine a year ago and it was a PITA.. definitely doable for anyone, but it's a tight fit with the bulb and clicking it in.
The bulb should be $2 at most.
-Nigel
Old 10-08-2016, 04:49 PM
irokdastar's Avatar
2004 CLK 500
is it a problem getting to it ? any pointers Thank you
Quick Reply: Ashtray light
