collant type and how to check level
Hello everyone I want to flush my coolant is there a compatible brand other than Mercedes coolant ? also how do I check the level of coolant ? Thank you
MBworld Guru
Xerex G-05 is compatible, acceptable, and usually readily available. The proper coolant level is check in the overflow tank. It should be right at the top of the "clear" section, where it meed the black top section. The system is self-purging, so after a drain, you may need to top it off once or twice after driving.
