Keyless Go Operational Question
I have an '04 CLK with Keyless-Go. No problem unlocking and starting, but I understand the Smartkeys are unique and the car can sense the seat/wheel/mirror setting for each key.
This doesn't seem to work.
I have the features already set for key dependent operation.
Am I correct in expecting that when one Smartkey or the other is brought into the car, adjustment to the appropriate seat position should occur automatically?
Perhaps putting it another way, how do I program the Keyless Go Smartkey to a particular seat memory?
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
The seat memories can be dependent on the key in the car, meaning with one key in the car, the three memory settings are saved; then with a different key, three more settings are saved.
-s-
I can see what you're saying. I re-read this portion of the owner's manual, and while not very clear, I see where it could be as you describe it.
I guess the bottom line is that regardless of which key you have, you still have to press the button on the door.
The good news is that this appeared to be the only "defect" in the car after 5 weeks and 2500 miles. Thus, no defects, what I would expect from MB!
That's not how it works. And the seat adjustments are never made automatically, seat movement always requires an action by a person (e.g. pushing the memory button) while any movement occurs.
Maybe I am mis reading your question but I took it as...for example, if a key was used and later you came back with keyless go and started the car, the settings should automatically move to your keyless go settings...am I correct here? Hope this helps.
No, that wasn't my question.
I was lead to believe (by the MB salesman, naturally!) that when key #1 got into the car the seats would automatically adjust to the pre-set settings for key #1. Likewise for key #2.
In other words, with a Keyless Go Smartkey, we would never have to press the seat setting on the door once it was set-up and somehow matched to the key. When I get in the car, the seat adjusts for me; when my wife gets in with her key, the seat adjusts for her.
I am starting to conclude this was an overstatement, it just doesn't happen that way.
