W208 Rack-n-Pinion Conversion Anyone?
2002 CLK55 AMG Cab
Just testing the waters to see if anyone would be interested in a conversion kit
for our 208's. I'm in the process of my own conversion ('02 55 Cab.) and documenting everything. Ever wonder why W210 E55 has a rack and we don't? Cheers
1 Post
2001 clk55 AMG
I was going to convert my 208 to rack & pinion when I was making headers for the car, the rack & pinion conversion would open up a lot of space for headers and maybe have a better feel to the steering
CLK55 / E350 Coupe
why did they use the recirculating ball steering anyways the W202 did not use it. Feels like crap coming from driving my E class, no driving with your knees
Car would feel so much sportier i think with rack and pinion.
2002 CLK55 AMG Cab
"no driving with your knees" I could not agree more. These cars are rockets in a straight line, go to turn and forget it... I can't wait to finish my project and report, the new rack is not the only tweek ( :
Most of the time the reason Recirculating ball feels bad is because the stock steering damper is bad. It costs only $25. Replacing the steering damper makes a world of difference in steering feedback. Most peoples steering dampers are bad and have been for a long time and they don't even know it.
2002 clk430
2002 CLK55 AMG Cab
I agree that a bad damper doesn't help matters, but the damper in new form is nothing more than a "patch" on a dated design. Live axle 4x4 pickups have dampers to control play and slop on their steering assemblies, a 208 is no pickup. Fact of the matter is most ALL other euro performance cars have had a rack n pinion since....forever due to the superior road feel and feedback associated with fewer torque points / moving parts between steering wheel and tie rod ends. That said, I would definitely replace a worn damper, its a good start in steering feel improvement.
2002 CLK55 AMG Cab
you are absolutely right CLK Operator, all of the pivot points in a recirc. ball sys. make great torque multipliers hence the lack of effort from driver. This one fingered input comes at a price which is that "disconnected from the road" feel. I've always been a Porsche and MBZ nut, a torquey a** 208 with precise steering and other tweeks may give me my cake and I can eat it too... ( :
The steering damper is literally 1-2 bolts, its VERY easy to do and its right in front. Most peoples are completely busted and they don't even know it. If you have a lot of slack and top dead center on the steering wheel and you have very little feedback, its most likely the steering damper. Did it on my C36 (same as W208) and it was literally night & day difference.
hope that helps
hope that helps
The 208 & 202 basically share the same setup and both use the same exact steering damper, it goes bad all the time. Its easy to check if yours is bad, if you see any fluid leaking outside the damper then its failed (much like a normal shock). Its $22-26 depending on where you buy it and you can do it yourself or any shop can do it for half hour of labor or less.
2002 CLK55 AMG Cab
p.s. you need to remove plastic belly cover to see it ( 4 screws ), anyway, hope this helps
you may be better off just doing normal suspension upgrades to get more feel vs. a full rack n pinion update. Polyurethane bushings, more aggressive sway bars, much stickier tires (dunlap Z1s) & etc will help as well.
2002 CLK55 AMG Cab
Anyway, for any who are interested, I will post some pics this WE when I'm in the garage again. This project has been a blast- Cheers
careful, thinking outside the box does not necessarily yield great ideas (or at least affordable ones). Seems like a lot of trouble (and $$) for not that much gain. Good luck with the project, it will be interesting to see the results.
Aside from a smaller front sway bar (or one that’s the same size but uses more pliable material), the following options may be beneficial; softer front springs, stiffer rear springs, a thicker (or stronger material) rear bar, wider front tires, narrower rear tires, or higher front tire pressures. If you have adjustable shocks, a softer setting up front or a stiffer setting out back. You already know to try one option at a time. Doing all at once may bring the back end around at turn 1.
