Sign in using an external account
| CLK55 AMG, CLK63 AMG (W208, W209) Discuss the past, present and future CLK55 AMG and the CLK63 AMG. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 |
Drives: w208 CLK55 AMG
Possible alternative front rotors for w208 CLK55 AMG
#2 |
Drives: FX35,W208 CLK55 Cabrio,2002 Camaro SS CE,1996 Camaro Z28 Convert
Not worth it. I tried the same with mine and decided the safety of my family wasn't worth saving the $200. Mercedes of Annapolis (MD.) has a website where the factory AMG rotors are $207 each.
#3 | |
Quote:
I have received the rotors. I will be verifying the dimensions this week. I found it interesting that the new rotors are directional. I am interested in why you would find these rotors unsafe. |
#4 |
one issue so far: the bolt the positions the rotor is on the wrong side of the lug hole. Easy fix.
#5 |
All the measurements are just a bit off but in almost every way.
Imagine hitting the brakes hard at 120 or so. Will you have peace of mind that everything is going to work as Mercedes designed it to? |
#6 | |
Quote:
I understand why it would make you uncomfortable. FWIW, I am an experienced engineer with 25+ years of building and racing cars. This is my first MB. It is an excellent piece of engineering. I have the new rotors this evening. So far so good. The pads bedded in without issue and the car stopped quietly without any drama. It is raining and the ABS performed as expected. More testing tomorrow to and from work......
#7 |
Drives: 2001 CLK55 AMG
any update, good/bad??? where did you get them? how much did they cost?
#8 |
They are working great. I was in a bind for time so I did not replace the pads. I would replace the pads at the same time next time. It just made the break in period longer with a little more noise. Everything is working well and quiet.
#9 |
Drives: 2002 CLK 55 AMG Coupé
#10 |
Drives: W211 E55
Those look to be made by Centric/StopTech. I have been in contact with Kevin@AutoTalent.com about brakes which he recommended going with Centric/StopTech. He is very helpful and quick to respond.
#11 |
Drives: 2001 CLK55
Thanks for the tip on Merc of Annapolis. The price is now $213 for front rotors, but still ~$30 cheaper than Autohaus/everywhere else I've seen.
Are you still using the aftermarket rotors? I see you were happy with them 6months later, how about 12months? Where did you find them?
__________________
Member #77 - AMG Orphans Club™ International |
#12 |
Drives: 2001 Clk 55 AMG
Get w209 rotors and w209 amg calipers!!! Car-Part.com or ebay has plenty for $150 per caliper but there upgrades...
#13 |
Drives: 2001 CLK55
I've heard different years of the 209 clk55 had different rotors and calipers, which one's would you recommend. Are 209 rotors compatible with 208 calipers?
__________________
#14 |
#15 | |
Drives: 01 CLK55, 00 ML55
Quote:
I see the concern for family with slight variations in tolerances/dimensions BUT HOPEFULLY THE FAMILY ISN'T TRAVELING AT 120MPH! ![]() I'm sure Darin M doesn't really do such, just thought it was a rather funny example!
__________________
#16 |
Just as a note, I typically look for cheaper solutions than factory Mercedes/AMG expensive solutions. But I will say, the vented design of the brakes is very cool and functional. For me, it's worth the $$ to have the brakes.
BTW, I've got 50k miles on my current rotors (just since I owned it) and they're not worn out yet. Actually the same pads as well. And I've taken it to the track twice.
__________________
#17 |
Drives: 2001 CLK55
Yeah, I never thought of the CLK, especially an AMG, as a family car...
You make a good point about the stock brakes. As there aren't many options in the aftermarket, I think I'd be hard pressed to find a better alternative without upgrading calipers as well.
__________________
#18 |
Drives: 2001 CLK 55 AMG
If you want to put the rotors from a 2003 CLK on your 2001 or 2002, you have to change the calipers and pads as well. It will work. I did the same swap on my car. It was actually cheaper to swap the calipers, pads and rotors from the '03 model than to replace the pads and rotors for the '01.
**EDIT** The calipers can be from an '05 - '07 C-Class (non V8) or the SLK from 3/06 - '10 (non V8). Those calipers are availiable aftermarket no problem. Last edited by Johawk79; 04-28-2012 at 02:21 PM. Reason: new info |
#19 |
Drives: CLK55 / E350 Coupe
Best i've seen for the W208 is to get the OEM rotors and take then to frozen rotors for their special conditioning.
__________________
![]() CLK55 - 2002 / E350 Coupe - 2011 Vogtland Springs / Koni Sp / VIPclk320 R Strut OZ Ultraleggera lightweight (18.3 lb) Green Filters + Catless / SprintBooster Pioneer AVIC-X910BT / Basslink Cailbre K40 Hidden Radar Jammer Ceramic 20% Gloss Tint |
#20 |
Drives: AMG
I did this. The rotors will last much longer this way.
__________________
![]() W208 CLK55 - 2002 (Original owner - 50K miles) 1 of 3,381 W208 AMG Coupes Worldwide 304WHP / 321TQ - Stock! W124 Estate - 1995 MBWGCM #71 Kombi's Uber Alles Member #3 Founder - AMG Orphans Club™ International (Don't have an engine builder's plaque on your factory AMG? You're an AMG Orphan!) Sign up here: http://www.mbworld.org/forums/clk55-...ml#post4374396 |
#21 |
slotted, dimpled?
__________________
#22 |
Drives: AMG
__________________
#23 |
Feels like i've asked you this before, i knew the answer
![]() Whats your take on dimpled or slotted from them? Was it not available when you had em done?
__________________
#24 |
Drives: AMG
Honestly, I never checked. If I were to go to aftermarket I may look at those kind of options. No real need/desire at the moment.
__________________
| Tags |
| 2001, amg, brake, burnie, clk, clk55, drilled, edge, front, glen, lip, rotors, slight, slotted, smooth, w208 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
