Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| CLK55 AMG, CLK63 AMG (W208, W209) Discuss the past, present and future CLK55 AMG and the CLK63 AMG. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 02 SLK32 AMG, 04 CLK55 AMG
W209 CLK55 oil consumption ?
#2 |
Drives: 2005 CLK 55 AMG
I'm pretty sure they didn't put enough in the 1st place. When the car tells you to put one it means to reach ok level not max level.
#3 |
Drives: CLK55, S500
Like MTLdude said, it might have been filled short. They need to put in around 8.5 quarts, max 9 quarts... depending on how much of the old oil drained out.
You can check the exact level by turning the key to position one (accessory mode) and then press and hold the cluster reset button until you hear a beep (it might take a while). Then press page up or down on the steering wheel (try down, then up, one of them will work, I forgot) and it should show oil level at the bottom line of the dyno mode specs. Turn the key to position 2 BEFORE START and it'll show an oil level reading. The car will reset out the dyno mode by completely turning the key back to the off position. It's very useful since we don't have a dipstick and is the only way to know how much oil to put into the car during an oil change. If you can't access this menu, put in 8.5 quarts. Disclaimer: I never have a problem doing this and it's nothing harmful, but research dyno mode first and try at your own risk. Last edited by AMG X; 07-27-2011 at 02:12 AM. |
#4 |
Drives: CLK55
Oil consumption is expected on AMG's. In the owner's manual says so. If you are using 1 quart every 3500 miles then you are very lucky, usually 1 quart every 1500 miles
#5 |
Drives: CLK55
Wifes C63 was using about 1 qt every 3400 miles.... up until 20K miles.... then for some reason it stopped using any.
My clk55 does not use any that I know of.... but to be honest it's been in the shop 75% of the 1 yr of my ownership
__________________
All hail Fleming Kleemann! |
#6 |
Drives: 2010 W212 E550
Burns about 1 Qt of Mobil 1 every 3,500 miles. Very consistent in that part. I've heard the E63 goes through 1 Qt every 1,000 miles!
__________________
W209 CLK55 AMG | 19" BRABUS Mono VI 2-piece | BRABUS Suspension | BRABUS Door pins *Sig thanks to Shake!* |
#7 |
Drives: CLK55
OK so I just put 1K miles with the blower... and guess what.... add a quart at next fuel fill up msg...... Oil was changed several months and several dyno sessions ago
__________________
#8 |
Drives: 2001 CLK55 AMG
I've used a half quart over 3,000 miles. I didn't track it as much as usual but even then I never touched a full quart. When I bought it, and ran a compression test the max variance between high and low cylinders was 8 psi. Needless to say I was dumbfounded.
#9 |
Drives: asdf
05 clk55 here. i've never had to add any oil for approx 15k miles of ownership. only last week did i have to add 1 quart in at which point I just did a complete oil change.
__________________
2000 C280 Aftermarket valve caps Super Cool Super Blue headlights Aftermarket 91 Octane Petrol |
#10 |
don't even sweat it.....i have to add 1 quart every 300 miles in my '04 clk 55
| Tags |
| 2001, 55, amg, amount, burning, clk, clk55, clk63, consuming, level, location, mercedes, mobil, oil, quarts, sensor |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
