Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > CLK55 AMG, CLK63 AMG (W208, W209)
Sign in using an external account
Register Forgot Password?
Home Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors TSB & Recalls
CLK55 AMG, CLK63 AMG (W208, W209) Discuss the past, present and future CLK55 AMG and the CLK63 AMG.
Welcome to MBWorld.org Forums
submit to reddit
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 07-17-2011, 02:07 PM   #1
Drives: clk55
where is cable to use OBDII Scanner?
Just borrowed one from O'reilly and looking for the pin cable on car
To remove this ad, register today or login if you already are registered!
prestonian is offline   Reply With Quote
Old 07-17-2011, 03:08 PM   #2
Drives: clk55
found it searching another forum... shows the Crank position sensor
as the culprit.
I took the plastic cover off my 2004 CLK55.
I am looking down the driver side between the engine and the tranny. There is so little room in here I cant see crap.
Can someome point me a little closer please.
Can I get to this from underneath the car?
TIA
Old 07-17-2011, 03:14 PM   #3
driver seat passenger compartment, look in a line directly below the key...7 inches down...7 inches forward, you will see the little door that exposes the plug.
__________________
2010 GLK350 4Matic Paladium Silver
2002 black CLK 55,Lorinser roof spoiler, illuminated AMG door sills, Eurocommand by Steve, black birdseye maple shift knob/door handles/arm rest, quad exhaust
cindyclk is offline   Reply With Quote
Old 07-17-2011, 04:04 PM   #4
Drives: clk55
I just looked and see no such door. I even took off a plastic trim piece below the steering column.
Mine is a 2004 model. Perhaps your 2002 model is different in this respect.
Old 07-26-2011, 04:46 PM   #5
MTLdude's Avatar
Drives: 2005 CLK 55 AMG
It's located near the hood release on the driver's side. There's a cover you need to flip to access it.
MTLdude is offline   Reply With Quote
Old 07-26-2011, 06:00 PM   #6
Drives: 05 CLK55 AMG
I'm pretty sure he found the OBDC connector and was able to read the code indicating the Crank Position Sensor to be the problem. (right?)
I replaced mine about 2 weeks ago, it was a *****. I removed the airbox and air flow sensor at the rear of the engine, then kneeled on the engine to get at it.
I had to do it all by touch, I wasn't able to actually see the CPS.
I was able to get the inverted torx socket on a swivel adapter in from the valve cover.
I wasn't able to get at it from the side, the fuel line and some plastics were in the way
Its ALL the way in the back here:
Under/behind these plastics. All the way down on the bell housing.
ambit is offline   Reply With Quote
MBWorld
Mercedes SLR McLaren
Paid Advertisement
submit to reddit
Tags
02, 63, amg, cable, clk55, connector, forum, ii, location, mercedes, obd, obd2, obdc, plug, w208
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld - Contact Us - MBWorld.org Forums - Archive - Top
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright © 2001-2011 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
