Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > CLK55 AMG, CLK63 AMG (W208, W209)
Sign in using an external account
Register Forgot Password?
Home Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors TSB & Recalls
CLK55 AMG, CLK63 AMG (W208, W209) Discuss the past, present and future CLK55 AMG and the CLK63 AMG.
Welcome to MBWorld.org Forums
submit to reddit
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 08-02-2011, 02:24 AM   #1
Drives: CLK55 AMG
w209 CLK55 headlight lens (cover) Question/Help
Hello All,
Cant seem to find anything, so before i embark in this "blindly" i would like to see if anybody have given this a go. I wanted to see if the Headlight lense can be removed to be cleaned.. Appears they have clips for removal?? Anybody ever done this? OR, does anybody know if anyone sells the lens alone? Dealership states its the complete headlight only that they sell...Annnnd of course, they didnt know if the lenses do come off..Anybody care to help or provide a DIY guide of sorts?
Thanks in Advance
Cesar
To remove this ad, register today or login if you already are registered!
C's-CLK55 is offline   Reply With Quote
Old 08-02-2011, 03:04 AM   #2
MarcusF's Avatar
Drives: FIA approved Pumas
If your goal is to clean the headlamps so they are no longer cloudy, they can be cleaned in place. I called Superglass and had them do it. For $50, they drove out to my house and did mine. The guy wanted to wash the car when he was done, but it was a little too hot. When he was done they were very close to new. Ask your local MB dealer who does theirs. The same company will probably do yours. Lastly, do not let them do this in the garage. The stuff they use splatters everywhere.
MarcusF is offline   Reply With Quote
Old 08-02-2011, 03:40 AM   #3
Drives: CLK55 AMG
Thanks! I had mine cleaned/buffed like ur pic above, but i feel the drivers side lens need to be cleaned from the inside too..cause there is a little bit of dibris inside. When i got the car the dealer replaced them bulbs with 8000k and i can only guess he made em dirty from the inside?? Although it wouldnt make sense cause u dont need to touch the lens when u replace a bulb.. So idk why its still a lil couldy. so i am looking to see if anybody knows how to take these puppies off. Thank your for the suggestion though!!
Old 08-02-2011, 04:53 AM   #4
elijah's Avatar
Drives: W209 CLK 55 AMG
Quote:
Do you have any before/after shots?
__________________
BLACJ on BLACJ
elijah is offline   Reply With Quote
Old 08-03-2011, 12:04 AM   #5
MarcusF's Avatar
The white stuff running on the bumber was polish residue. It washed off.
w209 CLK55 headlight lens (cover) Question/Help-rentawreck.jpg
Old 08-12-2011, 02:12 PM   #6
ZachG's Avatar
Drives: 2006 C55 AMG
Can you share mroe info on who superglass is? I would totally have this done for $50
ZachG is offline   Reply With Quote
Old 08-13-2011, 02:10 AM   #7
MarcusF's Avatar
It's a chain in most states with a dozen or so independantly owned/operated shops in California. I used the Los Angeles store which is owned by David Lilley. They specialize in windshield repair (try someone else if you're looking to replace a Benz windshield) and headlight lens resto. They aren't hard to find - superglass.com. If they aren't in your state or aren't local, many dealers use a shop to polish the headlamps on used cars. Find who your local dealers use and call them. Trust me, dealers aren't paying $50 a pop so they'll be happy to do yours. Get 19 of your friends (with faded out headlamps) to come over for a BBQ. You guys eat while he works and you may get whatever the dealer rate is. The savings will pay for food a couple of times over and the headlight resto tech will be delighted to do 20 jobs at one location.
Old 08-25-2011, 02:40 PM   #8
Drives: 2003 clk 55
for the people in the bay area, oakland doesnt do it. san jose said 100$ per light. and im waiting to hear back from san francisco...
cobrab19 is offline   Reply With Quote
Old 08-26-2011, 08:38 AM   #9
Drives: W211 E55, 911 turbo, 911sc, RX330
It is pretty easy to do headlight refinishing, just time consuming. I use the 3M Pro kit at my friend's shop to refinish headlights that are pure white instead of clear. After an hour or less, they look brand new. The 3M consumer kit can be found at Walmart for about $20 and it will do a pair of headlights. You use a drill and the kit comes with a 3" pad attachment and I think 500 and 800 grit discs, a 3000 grit wet disc and a polishing pad with rubbing compound. I go an extra step and get a good fine scratch remover/polish and that's it! The Pro kit comes with air random orbital air sander and air polisher, 500 grit and 800 grit discs, 1000 and 3000 grit wet discs, rubbing compound and polish, but it is @ $300 instead of $20. It will probably do about 12 cars.
I just redid the headlights on the ML320 last night and they look new.
WPOZZZ is online now   Reply With Quote
Old 08-26-2011, 03:03 PM   #10
Drives: '03 CLK55 AMG, '93 Slammed Civic eg hatch(DD)
Mine had oxidation on the inside, I tried many products from quixx, meguiar's, and 3m on the outside and found that none of them did anything, So I opened it up, mine did not have any clips. Just glue, I used a heat gun and a butter knife to open it. And used the meguiar's headlight restoration kit, and it worked.
tkhuuyip is offline   Reply With Quote
Old 08-27-2011, 12:44 AM   #11
Drives: 2003 clk 55
san fransico called me back and said the can come tuesday and it would be 35-45 per light. pretty inexpensive if u ask me. ill post before and after pics as well...
Old 08-28-2011, 08:25 PM   #12
Drives: 2003 clk 55
Quote:
hey u said they were glued on? how did u get them back on?thanks
Old 08-28-2011, 09:15 PM   #13
503C43 ////AMG's Avatar
Drives: 1 out of 1125 C43's imported to U.S.A
You can buy the 3M kit online from Walmart for $16 (that's with shipping included)
__________________
  • 19" Mandrus Milleniums (8.5" + 9.5")
  • Vogtland Springs
  • Bilstein Sports
  • K-MAC Camber/Castor kit
  • MB Arts Rear Camber arms
  • 2nd Cat + Res. Delete
  • Cryo Treated AMG Rotors
  • Stoptech SS Brake Lines
  • Akebono Euro Brake Pads
  • HID Lights + HID Crystal fogs (55w 6k)
  • Tinted Windows (20%)
  • Avantgarde Grille
  • Evosport UD Pulley kit
  • Evosport Phenolic Spacers
  • Renntech CF airbox
  • AFE Pro Dry S Filters
NEXT:
  • Eurocharged ECU Tune (Purchased)
  • Kleemann Headers (Awaiting install)
  • Metal Cats
503C43 ////AMG is offline   Reply With Quote
Old 08-29-2011, 11:43 AM   #14
Quote:
Well there was enough glue for me to just push it back in, and use the heat gun to melt the glue again, and push the lens back into place. So far no moisture build up or anything.
MBWorld
Mercedes SLR McLaren
Paid Advertisement
submit to reddit
Tags
2003, 2005, 55, clk, clk55, cloudy, headlamp, headlight, kit, lens, mbworld, mercedes, recondition, restore, w209
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld - Contact Us - MBWorld.org Forums - Archive - Top
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright © 2001-2011 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
