Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| CLK55 AMG, CLK63 AMG (W208, W209) Discuss the past, present and future CLK55 AMG and the CLK63 AMG. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: Clk 430 amg
Can drive my car in desperate need of help!
#2 |
Drives: FIA approved Pumas
A P07xx can point to a bad speed sensor or an issue with the plate that holds the sensors (there is more than one sensor on the plate). The plate and sensors are "in" the transmission. Not “on”, but “in”. To get to it, you drop the transmission pan, remove the filter, remove the valve body, extract the plate that holds the input and output sensors, and then with the plate on the workbench it can be repaired (there is a kit to replace the electrical contacts, or a sensor could be bad, or something else).
I have some degree of background in cars and I personally wouldn't do the job if the dealer charged twice their going rate (although I might pay Sun Valley instead). I don't want you to take this the wrong way, but "I think" if the oil change overwhelmed you, you may wish to consider staying away from attempting a DIY transmission fix. You may want to have it towed to the nearest dealer. |
#3 |
Drives: 2001 CLK 55 AMG
try resetting the computer.....unplug the battery for 10-30 seconds....do not close the trunk and reconnect it....if problem persist. go to dealer....when it is stuck in first gear the ecu has it in "limp" mode.
#4 | |
Drives: 1 out of 1125 C43's imported to U.S.A
Quote:
__________________
#5 |
Drives: Slk55, Clk500 Cab., C350, Civic
#6 |
it can be either bc he said he only removed 2 qt and added 7 to the engine. that would put it at 13.5 to 14 qt in the engine.
#7 |
I have a feeling you drained the transmission. that sounds about right to have 2 quarts come out of the trans drain when you dont drop the pan
__________________
W210: Resonator delete/x-pipe - AMS headers - EC tune W211: Stock w/ cooling mods FOR SALE: VMR V710 rims - http://mbworld.org/forums/wheels-tir...y-area-ca.html W211 E63 rims - http://mbworld.org/forums/wheels-tir...y-area-ca.html |
#8 |
Drives: Clk 430 amg
Thanks for the answers and yea i deff drained the tranny fluid i have one more question bc i just picked up some tranny fluid today...there is what appears to be a insert for tranny fluid below air filter in the top back of the motor is that where it is supposed to go??
#9 |
Drives: Clk 430 amg
need to know location of tranny dipstick clk 430
I thinkk i found the insert for the tranny fluid below the air filter is that deffinitely the spot?
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
