Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| CLK55 AMG, CLK63 AMG (W208, W209) Discuss the past, present and future CLK55 AMG and the CLK63 AMG. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2001 CLK 55 AMG
brake pad replacement
#2 |
Drives: 1 out of 1125 C43's imported to U.S.A
I checked the WIS and it looks like you have the same brake setup as the C43. I just did this (I replaced rotors, calipers, brake lines, and pads) and as long as you have the correct tools and don't mess anything up (I cross threaded my caliper when reinstalling the brake lines) it shouldn't take you more than a couple hours to replace both sets of pads up front.
You will need a 7mm allen wrench to remove the caliper guide pins and an S10 torx bit (this is to remove the brake pad wear sensor that is attached to the caliper, you can probably get away without removing this but it will make it much easier) Pretty easy to do 1.) remove the wheel 2.) remove the brake pad retaining clip 3.) remove the caliper guide pins 4.) remove the brake pad wear sensor from the caliper (not necessary but makes it easier) 4.) pull the caliper off (you might need to pry it off with a screw driver or something) Make sure you do not let the caliper hang by the brake line, use a bungee cord or zip tie to support the caliper. hope this helps
__________________
#3 |
Drives: clk 500 (wifey's); 350Z roadster (daily driver); 350Z coupe (track car)
Do you need to remove the caliper?
__________________
03 CLK 500: Brabus suspension / H&R sways / AMG Styling IV F18x8.5, R18x9.5 / AMG front brakes / Carlsson quad exhaust / Euroteck front lip / AMG rear lip |
#4 |
Unless you have figured out a way to remove the brake pads through osmosis, yes...
![]() The caliper doesn't need to be disconnected from the brake line but it does need to be removed from the mounting bracket in order to get the brake pads out
__________________
#5 |
so the new pads can be installed and compressed with a C-clamp like domestics?
#6 |
Location: Switzerland: Locarno (TI), the canton of merlot wine, grappa and fine food
Drives: 98' C240T, 99' C43 AMG "T Rex"
__________________
AMG OCI Member #4 Check garage for more details |
#7 |
__________________
#8 |
awesome! any chance you have any wiring data for the w208/55? nothing wrong with the electrical but a good contingency nevertheless.
#9 |
x2 503 u da man! TY!
| Tags |
| 1999, amg, brake, c43, change, clk55, cost, dealership, instructions, light, mercedes, pad, pads, replace, replacement, rotors, wear |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
