Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > CLK55 AMG, CLK63 AMG (W208, W209)
Sign in using an external account
Register Forgot Password?
Home Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors TSB & Recalls
CLK55 AMG, CLK63 AMG (W208, W209) Discuss the past, present and future CLK55 AMG and the CLK63 AMG.
Welcome to MBWorld.org Forums
submit to reddit
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 09-05-2011, 06:49 PM   #1
Drives: '03 CLK55 AMG, '93 Slammed Civic eg hatch(DD)
Finished Radio Install
After a year and a bit with the Bose system, non-navi, on a 2003 CLK55 w209, I've finally decided to upgrade the head unit. I've been to several local audio shops in my city asking for advice about keeping the Bose speakers because I did not feel like rewiring everything. They told me about it being fiber optics, but through research its just after the amp is where it becomes fiber optics. But the problem with the Bose speakers is their resistance being 2ohm's, where most aftermarket audio is 4ohm's. So I decided to gut everything and start fresh.
This build was on a budget, I am still a student attending uni, and I need as much saved up as possible.
Headunit: Clarion VX400 - $200 (Purchased locally)
Speakers: F: Alpine Type R SPR-174A - Free from a friend R: Clarion SRR1625- Free from my brother (all are new)
Subwoofers: 2 12's Alpine Type R - $100 (got it cheap from a friend)
VW Harness: $15 (purchased from Advance)
Radio Adapter: $10
Amplifiers: Sony Xplod -$100, I know sony is not good in car audio, but it was all I had, But I decided to buy an MB Quart amp for the subwoofers
MB QUART FX1.600 - $180 (Both purchased from visions)
Wires: $30 (Brian Reimer)
All the places listed above are in Winnipeg, Manitoba.
Total: $635
Note on install, you may need to modify the factory speaker mounting bracket.
For my alpine speakers, the bottom portion were sticking out a bit.
Marked the spots were I had to cut. Used a dremel.
After:
There is a piece that sticks out on the bottom part of the bracket, You have to cut it.
After: Fits perfectly
Before Pics of the old Bose Unit:
For the 12v accessory and Dimmer Wire, I went to the cigarette lighter for them, Thanks to 2MCHCAR, for his post about this, otherwise I would still be looking for it.
12v accessory = Black/Yellow Wire
Dimmer/Illumination = Blue/Grey
Tapped into them
At first I used a Self tapping connector, But they didn't work that well. So I just spliced them, and used a butt connector.
Tested before putting it back in.
I tucked everything on the driver side, using the cover underneath the steering wheel
3 Torx bit screws hold it in place.
This tool is so handy! Without it, it would have been a b*tch to feed the rca's through.
Here is a pic of how I tapped into the fusebox for a remote wire for the amps
Sorry its blurry
Before:
After:
No Dash kit, Still waiting on it. So I used foam in the mean time.
Here is a picture of the wires being spliced and additional wires being added to them to extend them to the amp
The grey extended wires are for the Rear Speakers
The Copper extended wires are for the Front Speakers
Sorry I forget which is which, but you have a 50/50 chance haha.
To remove this ad, register today or login if you already are registered!
__________________
6000K HID | Fog Light Delete | K&N Filters | 2nd Cat Delete |
tkhuuyip is offline   Reply With Quote
Old 09-07-2011, 01:56 AM   #2
MarcusF's Avatar
Drives: FIA approved Pumas
A PAC-OEM2 would have allowed you to keep the BOSE amp and OE speakers. The PAC-OEM2 takes the unbalanced signal from the head unit, converts it to balanced signal (same as your OE head unit produced), and that signal is then passed to the BOSE amp. That setup would have been
headunit ----> PAC-OEM2 ----> wiring harness adapter.
The original PAC-OEM2 converter is no longer in production but new old stock units are available for $28 at Amazon. I've heard there is a replacement for the out of production OEM2, but I don't remember the model number.
Are you going to use the steering wheel controls with the new headunit?
MarcusF is offline   Reply With Quote
Old 09-07-2011, 03:00 AM   #3
LOL, too late now, don't wanna go through that again.
And perhaps down the road, I do find that reaching over to the head unit whenever I want to change songs is quite inconvenient.
__________________
Old 09-07-2011, 04:46 PM   #4
MarcusF's Avatar
This is a DIY from when I did mine. It covers the head unit and the steering wheel controls. It was plug and play - no factory/Mercedes-Benz wires were cut.
Old 09-07-2011, 05:18 PM   #5
I have to admit, that looks like a very clean install you've managed. Very thorough. Good job! The way you had everything planned seem so organized. Mine is roughly drawn with squares. haha
__________________
MBWorld
Mercedes SLR McLaren
Paid Advertisement
submit to reddit
Tags
alpine, amg, benz, clk55, clk63steeringwheelcontrolsaftermarket, cts, harness, mercedes, model, oem, pac, radio, remove, stereo, w209
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld - Contact Us - MBWorld.org Forums - Archive - Top
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright © 2001-2011 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
