Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > CLK55 AMG, CLK63 AMG (W208, W209)
Sign in using an external account
Register Forgot Password?
Home Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors TSB & Recalls
CLK55 AMG, CLK63 AMG (W208, W209) Discuss the past, present and future CLK55 AMG and the CLK63 AMG.
Welcome to MBWorld.org Forums
submit to reddit
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 10-01-2011, 09:12 PM   #1
betrezra's Avatar
Drives: CLK55
Codes tonight
Got CEL tonight, easy driving picking up dinner in the 04clk-k:
P0171 System too Lean (Bank 1)
Also got Bank 2 same code for Bank 2.
Quick search says it's MAS, or O2 sensors, or vac leak.
Time to diagnose.
To remove this ad, register today or login if you already are registered!
__________________
All hail Fleming Kleemann!
betrezra is offline   Reply With Quote
Old 10-02-2011, 01:30 AM   #2
Klinh's Avatar
Drives: Slk55, Clk500 Cab., C350, Civic
I reset codes, checked for vac leaks (all OK), hooked up dash-daq, watching fuel trims, 02 readings...... no CEL, no more codes, all seems OK now, after another 20 miles of various driving conditions. NO WOT runs until I figure this out. No codes or issues after reset and 20 miles.
Just want to confirm with you.... I suspect it's my ebay MAS Air Meter which came from german auto supply in a Bosch box.... but perhaps it was a reman or bad unit?
Ordered a new Bosch unit from Autohauz, AZ.
Does this sound like my MAS is going out?
I'm running stock paper filters.
Fleabay MAS has literally 5K miles on it.
thx.
I see a wide-band O2 sensor in my future just for pc of mind.
It does sounded like the MAS due to lean runnung on both banks but then it should also show another code for the bad MAS. It could also be your fuel pump issue. Are you running a boost-a-pump to up the pressure on your fuel pump?
Klinh is offline   Reply With Quote
Old 10-02-2011, 07:28 AM   #3
betrezra's Avatar
Drives: CLK55
No boost a pump.
Only stock fuel pump with 30k miles.
Kleemann boost sensative fuel pressure regulator (ups fuel pressure w/ ref boost).
I'm ordering a zeitronics wideband o2 sensor for pc of mind.
__________________
Old 10-02-2011, 09:03 AM   #4
betrezra's Avatar
Drives: CLK55
pardon duplicate post.
__________________
Old 10-02-2011, 09:26 AM   #5
betrezra's Avatar
Drives: CLK55
A-ha! Success.
Pulled air intake off, and inspected everything:
The little rubber hose from the mass air meter to the drivers side valve cover had popped off the drivers side valve cover.
Cleaned it up, and then went over every hose connection with zip ties.
Something all you kleemann guys should watch out for (if you already don't).
I find myself inspecting this motor every couple weeks just for good measure.
Wideband O2 sensor setup still in the works, for safe measure.
Thx all.
__________________
Old 10-02-2011, 06:41 PM   #6
PTE
PTE's Avatar
Drives: 03 CLK5.5 AMG
P0171 System too Lean (Bank 1) Also got Bank 2 same code for Bank 2.
Go Show Jeff. A level head & And straight thinking
Cheers _PTEngineering
PTE is offline   Reply With Quote
Old 10-02-2011, 07:34 PM   #7
betrezra's Avatar
Drives: CLK55
Trying to take after the zen-master PTE
Thx for your support sir on all things that go FAST!!!!!!
I'll post up results when I get the Zietronics Wideband hooked up with data-logging.
I really want the data-logging working BEFORE I take it to the track.
__________________
Old 10-03-2011, 05:07 AM   #8
Drives: moter bike
Codes tonight
its so nice to visit here a nice thread. Am so impressed with your such a good hard work, its definitely a good and diferent idea for others, you guys are doing good work good luck, keep it up..
__________________
Seo is the way to increase a website promotion.
jack shiny321 is offline   Reply With Quote
Old 10-03-2011, 06:07 AM   #9
Kevwood's Avatar
Drives: '05 C200K SS, '05 Kleemann CLK500K & '92 Z34 5sp (track car in Canada)
A-ha! Success.
Thx all.
Well done
__________________
Kleemann S8 CLK500<
Kleemann supercharger, cams, headers & tune | H&R springs and sways | Koni adjustable suspension |
Brembo GT BBK (6F/4R piston, slotted floating composite rotors) | Carbon fiber front lip & rear diffuser |
Custom Magnaflow exhaust, quads with 100 cell cats | GPT pulley | Vorsteiner carbon fiber rear spoiler |
Quaife LSD | E55K airbox & kevlar tubes | Magnecor KV85 wires | 360 Straight 5ive wheels, carbon fiber |
Mods/build thread
Kevwood is online now   Reply With Quote
Old 10-03-2011, 08:46 AM   #10
betrezra's Avatar
Drives: CLK55
Thx gents. I could not keep this car going w/o this community.
__________________
MBWorld
Mercedes SLR McLaren
Paid Advertisement
submit to reddit
Tags
clk55, codes, leak, oxygen, sensor, vacum, w208
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld - Contact Us - MBWorld.org Forums - Archive - Top
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright © 2001-2011 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
