Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > CLK55 AMG, CLK63 AMG (W208, W209)
Sign in using an external account
Register Forgot Password?
Home Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors TSB & Recalls
CLK55 AMG, CLK63 AMG (W208, W209) Discuss the past, present and future CLK55 AMG and the CLK63 AMG.
Welcome to MBWorld.org Forums
submit to reddit
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 10-16-2011, 02:00 PM   #1
400HP55's Avatar
Drives: 2001 CLK55 AMG
Parts Look Up/Help Please!
I need a part look up please I dont have it on the item.
Its the spark plug wire on the driver side closest to the driver. Its gonna be the bottom spark plug wire.
I need the part number for that wire so i can see if i can get it for less than MB wants. They wanted $56.00 for that sparkplug wire.
Or any other suggestions?
I found my coil pack and that spark plug wire had tons of calcium build up on them and I tried to clean it but I think thats why im getting missfire issues.
I changed my MAF and it worked for a while but as soon as I strated hitting 5-6k rpms it started again. The MAF did fix the problem at first but now its back.
I also noticed with my new intake the MAF bracket pops off from time to time causing the MAF to turn a little to the side. Maybe this is the problem to cause the MAF isnt reading air coming stright in...
What do you guys think????
Thanks all!!!!!
To remove this ad, register today or login if you already are registered!
__________________
AMG Orphans Club International #46
Custom 19X9.5 - 19 X 10.5 on Falken 452's.
AMG Emblems (Trunk, Steering Wheel, Hood, Rims)
W209 V.2 Intake
W209 Engine Mounts
Engine Swap/Rebuild
More To Come...
400HP55 is offline   Reply With Quote
Old 10-16-2011, 10:51 PM   #2
MarcusF's Avatar
Drives: FIA approved Pumas
I'd replace all the wires. The complete Bosch wire set is part number 09850, available at Rock Auto dot com for $165.
MarcusF is offline   Reply With Quote
Old 10-17-2011, 09:24 AM   #3
400HP55's Avatar
Do you think this is the problem? But then i dont see how changing my MAF would have worked for a week and then it starts again...
__________________
W209 V.2 Intake
W209 Engine Mounts
Engine Swap/Rebuild
More To Come...
Old 10-22-2011, 01:22 AM   #4
MarcusF's Avatar
Quote:
I have no idea. However, replacing 11 year old wires that have build up in a car that has issues at high RPM couldn't hurt. I'm doing mine with the next plug change, which is coming up soon.
Old 10-23-2011, 06:07 PM   #5
400HP55's Avatar
I figured since it has almost 100k miles I made a 100k tune up list:
Valve Cover Gasket Ordered
Oil change Waiting
Transmission filter and Fluid Change Waiting
Diff Fluid Change Waiting
Brake Fluid Flush Done
Cabin Air Filter Ordered
Air filters Done
Collant System Flush Waiting
Serpentine Belt Done
Idler Pulley Waiting
Spark Plugs Done
Wires Ordered A Few
Fuel Filter Done
Motor/Trans Mounts Waiting
Exhaust Hangers Waiting
Crank Position Sensor Waiting
Camshaft sensor Waiting
Power Steering Flush Waiting
Diff Side Seals Waiting
Thermostat Ordered
Drag Link Waiting
Front Lower Bushings Waiting
Front wheel bushings Waiting
Most of the stuff I'm waiting to either order, or take to the shop to do. Have I forgot something???
Should run around 1500 for the parts. Most is DIY.
__________________
W209 V.2 Intake
W209 Engine Mounts
Engine Swap/Rebuild
More To Come...
MBWorld
Mercedes SLR McLaren
Paid Advertisement
submit to reddit
Tags
09850, amg, benz, bosch, hood, label, part, parts, set, wire
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld - Contact Us - MBWorld.org Forums - Archive - Top
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright © 2001-2011 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
