Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| CLK55 AMG, CLK63 AMG (W208, W209) Discuss the past, present and future CLK55 AMG and the CLK63 AMG. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2003 CLK55
replaced maf and crankshaft sensor and new code came up
#2 |
Drives: CLK55
Cam shaft pos sensor is at front psg side of motor. Easy to replace.
Do a search for cam shaft pos sensor. GL.
__________________
All hail Fleming Kleemann! |
#3 |
Drives: 2003 CLK55
so i replaced the camshaft sensor and still didnt solve the problem. so right now i replaced the maf, camshaft sensor, and crankshaft sensor. i did notice that between the connectors of the camshaft sensor theres oil. when i disconnected it theres oil inside the connector. can that cause a bad connection issue and throwing off the camshaft sensor?
#4 |
Drives: CLK55
Buy a scanner and pull codes again. Codes will give you a starting point.
What is it doing? stalling? rough idle?
__________________
#5 |
Drives: '05 CLK55, '04 CLK320
I think I have a similar issue, my car dies as soon as it cranks up. I pulled the code and it said maf but Ive read different symptoms when the maf goes bad. Its not the crank position sensor because it doesnt stall after being warmed up. What are the symptoms of a bad cam shaft sensor? I cant really find any doing a search
#6 | |
Drives: 2003 CLK55
Quote:
at first it was a starting issue. it would just crank and not start but after a couple tries it would finally start. i was told it was crankshaft sensor so i replaced that. the problem was still there. then a code for maf came saying low input, so i replaced he maf. then another code came up P0341 which is the crank shaft pos sensor. so i replaced that and still theres a problem. starting issue, rough idle, and stalls. |
#7 |
Drives: CLK55
Other ideas: fuel filter dirty, fuel pump dying? O2 sensors?
Parts are too expensive on these cars to just throw parts at it trying to solve you problem.... I'd prob go to dealer or a good indie at this point..... to get hands-on diagnosis..... I have a Dash-Daq which reads the ecu read-outs real-time while I drive... it can be useful for trying to decipher problems. Also check for simple easy things.... like loose or missing or cracked vac hoses.... a vac leak will cause idle problems. Make sure MAS meter is secured properly into the rubber connectors.. there should not be any vac leaks anywhere. Make sure MAS Meter plug is securely fitted. Make sure the new CPS you installed is a good unit... best bet is to get a new one from Autohauz AZ...... If you're still getting a crank pos sensor code.. then you may have another bad CPS....... GL.....
__________________
#8 | |
Drives: 2003 CLK55
Quote:
its not the crank pos sensor code thats coming up its the camshaft sensor P0341 Camshaft position sensor Sensor A Circuit Range/Performance (Bank 1 or single sensor) i triple checked all that, hoses, wires, etc... |
| Tags |
| cam, camshaft, car, cel, code, codes, coming, crank, crankshaft, maf, mb, position, replaced, replacementproblems, sensor, shaft, stall |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
