Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| CLK55 AMG, CLK63 AMG (W208, W209) Discuss the past, present and future CLK55 AMG and the CLK63 AMG. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 03 CLK 55 AMG
Are Kleemann headers smog legal in CA?
#2 |
Drives: '05 C200K SS, '05 Kleemann CLK500K & '92 Z34 5sp (track car in Canada)
They aren't SMOG certified but if you've got a shop who looks the other way then you're doing okay. I don't see any reason why you wont pass the sniff with the secondaries in place - I'm being told here that a set of 200 cell high flows are more than enough to pass the test, another guy told me 100's will pass...?
__________________
Kleemann S8 CLK500< Kleemann supercharger, cams, headers & tune | H&R springs and sways | Koni adjustable suspension | Brembo GT BBK (6F/4R piston, slotted floating composite rotors) | Carbon fiber front lip & rear diffuser | Custom Magnaflow exhaust, quads with 100 cell cats | GPT pulley | Vorsteiner carbon fiber rear spoiler | Quaife LSD | E55K airbox & kevlar tubes | Magnecor KV85 wires | 360 Straight 5ive wheels, carbon fiber | Mods/build thread |
#3 | |
Quote:
I realize this is not the optimal performance setup, I just want to keep her as queit as possible. Last edited by 03renntechamg; 11-22-2011 at 04:23 AM. |
#4 | |
Drives: Slk55, Clk500 Cab., C350, Civic
Quote:
Everyone that i know with header got issue with check engine light come on related to the header. For some, the only way to fix the issue is by turning of the sensor. This is an issue when smog check, you will get an "system not ready" status and fail. The only way to get the "system ready" status is by turning on the sensor but then you might get the check engine again and will fail the test. |
#5 | |
Quote:
__________________
#6 |
Drives: W211
If you get kleemann headers or pretty much any other headers that delete the primary cats, you will need to get a tune to "turn off the rear o2s", but also need to make sure that its still "ready mode"
__________________
![]() ![]() 05 E55: K&Ns, MBH LTH, Renntech 168mm, EC H/E, 010 Bosch, HRE 547r, TTM scoops, CF VRP Engine cover, AZN Leds Custom tuned by Jeremy @ 06 E500 4matic: K&Ns, Renntech V3 ELM, |
#7 |
I think as long as you have 1 set of cats on your car you will be fine
#8 |
Drives: 2003 CLK55AMG
I would also think if you have cats on the car it should be good to pass. The car will throw a code for the deleting cats but a tune can turn it off. Let us know what you end up doing!!!
| Tags |
| amg, bbk, biggest, ca, carbon, cat, checks, clk, clk55, code, gains, headers, kleeman, kleemann, legal, power, smog, w208 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
