Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| CLK55 AMG, CLK63 AMG (W208, W209) Discuss the past, present and future CLK55 AMG and the CLK63 AMG. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 1987 gta
maybe buying amg,, couple questions..
#2 |
Drives: 2001 CLK55 AMG
Well,
The 4 ways I proved mine was a AMG before I bought it were: 1. AMG on steering wheel (you can fake this pretty easy). 2. Cluster has AMG on it, which would be a bit more costly to fake but is still possible. 3. Run a carfax (vin number will tell you a lot - I forget which numbers to look at) 4. I had the oil pan dropped, looked up into the cylinders, and saw AMG stamped on the bottom of the pistons =D This method costed about $150.00 but it was worth it. It was also cool to see the silicone cylinder lining... Hope this helps!
__________________
AMG Orphans Club International #46 Custom 19X9.5 - 19 X 10.5 on Falken 452's. AMG Emblems (Trunk, Steering Wheel, Hood, Rims) W209 V.2 Intake W209 Engine Mounts Engine Swap/Rebuild More To Come... Last edited by 400HP55; 12-15-2011 at 10:28 PM. |
#3 |
Drives: 1987 gta
this is the pic of the engine... not sure if the 430 v8 looks different but maybe this will help
#4 |
Drives: CLK 55 AMG W208
where is the air box on the engine? the CLK55 has 4 pistons front caliper and 2 pistons rear hope this help. you can run the vin# to verified if its true AMG or not
#5 |
Drives: 1987 gta
the air box sits on top of the engine and it has 2 ducts running to the front by the radiator.... do you know which vin digit do I need?...
#6 |
If you Carfax the whole Vin it should tell you. I cant recall which numbers in the vin tell you weather or not its real. As far as AMG vs CLk430 engine appearances, its really hard to tell.
"The position of each letter or number in the VIN code reveals important information about where and when your Mercedes was made, the type of engine it has, the model or series of the car, various equipment/attributes and its production sequence. Each character or digit has a particular purpose as follows:" http://northernresource.com/mercedes...in-decoder.htm
__________________
AMG Orphans Club International #46 Custom 19X9.5 - 19 X 10.5 on Falken 452's. AMG Emblems (Trunk, Steering Wheel, Hood, Rims) W209 V.2 Intake W209 Engine Mounts Engine Swap/Rebuild More To Come... Last edited by 400HP55; 12-15-2011 at 11:03 PM. |
#7 |
Drives: 02 CLK430
The AMG motor has an oil cooler mounted to the filter housing (shiney finned thing to the left of the filter cap), the 430 motors do not. Requires replacing the front cover. And the brakes, front brake calipers/rotors are much bigger than the 430s, and the rear rotors are vented not solid. The VIN will be WDB**74, the two asterics are where two letter would be, the main part is the 74. 74 = AMG. 70 = 430.
#8 |
Drives: 2005 CLK55 Coupe
Like others have said VIN is the best way. Take the VIN to the MB dealer, and ask for a print out. IT will show what options it had and such, also it will note what model it is.
__________________
2005 Mercedes-Benz Brilliant Silver CLK55 AMG Coupe [Kleemann Tune] [Kleemann Headers] [Renntech CF airbox] [Twin AFE's] 13.04@108.27 - TBD - Before Renntech CF airbox "1 of 247" 2001 Mercedes-Benz Brilliant Silver ML55 AMG [AFE Pro-Dry S] "1 of 1105" 2001 Mercedes-Benz Brilliant Silver CLK55 AMG Coupe [Twin K&N's] [LET Tune] 13.52@105.90 - 311whp/360wtq "1 of 1343"{SOLD} |
#9 |
Drives: 1987 gta
Sweet,,, vin has the 74.......some jerk wad must have cheaped out and put the 430 brakes on it to save $$$$$$. The new owner put a big brake kit on the back so now if it goes through Ill have to upgrade the fronts eventually
| Tags |
| 2001, amg, badge, clk55, cluster, difference, location, plugs, replace, spark, telling, true, vin, w208, w209 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
