Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| CLK55 AMG, CLK63 AMG (W208, W209) Discuss the past, present and future CLK55 AMG and the CLK63 AMG. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2001 CLK55 AMG
W208 AMG Tear Down - Top To Bottom
__________________
AMG Orphans Club International #46 Custom 19X9.5 - 19 X 10.5 on Falken 452's. AMG Emblems (Trunk, Steering Wheel, Hood, Rims) W209 V.2 Intake W209 Engine Mounts Engine Swap/Rebuild More To Come... |
#2 |
So with the camshafts/valve train out on the passenger side its time to remove the intake manifold...
Pic#4 - Just a quick glance into the intake valves that are on top of cylinder #3, if you recall these valves were suspected to be my knocking sound, they feel and look good. Who knows how they look under. Taking off the cylinder head later will show exactly what was wrong.
__________________
AMG Orphans Club International #46 Custom 19X9.5 - 19 X 10.5 on Falken 452's. AMG Emblems (Trunk, Steering Wheel, Hood, Rims) W209 V.2 Intake W209 Engine Mounts Engine Swap/Rebuild More To Come... Last edited by 400HP55; 12-24-2011 at 02:39 PM. |
#3 |
When we take the intake manifold apart here is what is inside. Its fairly complex...
Pic#5&6 - There are both long and short plenums for low and high rpms. These butterflies are open on lower RPMS and closed on high RPMS to sustain perfectly balanced airflow for all RPMS. They switch back and forth depending on RPMS. Very interesting!
__________________
#4 |
Here is most of the intake manifold system and the fuel rail and injectors. I'll be getting all of this hot tanked a restored, possibly polished. Next is the cylinder head. Stay tuned...
__________________
AMG Orphans Club International #46 Custom 19X9.5 - 19 X 10.5 on Falken 452's. AMG Emblems (Trunk, Steering Wheel, Hood, Rims) W209 V.2 Intake W209 Engine Mounts Engine Swap/Rebuild More To Come... Last edited by 400HP55; 12-24-2011 at 02:57 PM. |
#5 |
Drives: CLK55
Great Write up with Pics too.
Subscribing!
__________________
All hail Fleming Kleemann! |
#6 |
Drives: 02 CLK 55 AMG,09 C63 loaded with P30
The insides look clean. Not gunked.
__________________
02 CLK55-13.1@108.6 stock 95 C36 sold 09 C63-12.6@115 stock OE-tuning-only tune stock filters,charcoals intact-11.9@118.5 best trap 119 60-130 in 8.71sec "VERIFIED"-6speedonline.TUNED ONLY .Stock filters,charcoals intact,93oct. Everything else stock. |
#7 |
Ok guys take a look at this and tell me what you think!
On pic #3 - Its really scratched .... The pistons rock when I push on them.
__________________
AMG Orphans Club International #46 Custom 19X9.5 - 19 X 10.5 on Falken 452's. AMG Emblems (Trunk, Steering Wheel, Hood, Rims) W209 V.2 Intake W209 Engine Mounts Engine Swap/Rebuild More To Come... Last edited by 400HP55; 01-02-2012 at 03:45 AM. |
#8 |
Bottom of cylinder head. The cylinder that was scratched was black and the spark plugs were caked with oil...
__________________
#9 |
Drives: None
On the very first picture, it looks like you got a W209 engine. I don't know if that means you are using a W209 cover on the W208 motor. The picture with scratched cylinder wall, is that the one where you heard strange sound?
#10 |
You mean the air cleaner. Ya it fitted it onto the W208 - it was a challenge to say the least...
Well the noise sounded like the 3rd cylinder from the front... but after looking at this I'm thinking it was that one.
__________________
#11 |
Drives: CLK55
Did leak down test show anything with cyl 3?
The pics appear cyl 3 is getting oil past the rings of the piston, looks like no spark/ignition on that cyl (oily plugs), looks like possible piston ring damage (cracked ring) scoring on cyl walls. I'd drop that piston and inspect. If this were an old dodge slant 6, I'd run a $5 autozone cyl hone on it, and pop in a cleaned up piston with new rings and go to town...... someone more knowledgable about the star cyl walls/r*r will have to chime in on your options here. Thanks for sharing your journey.
__________________
#12 |
Drives: CLK55
__________________
#13 |
Drives: Innovation
My money is on cracked ring land/s
#14 |
Drives: 03 CLK5.5 AMG
Can you say , An 8 pack of 1st over pistons
You have a nice winter project. unless you have an isolated problem to just that cylinder. ( Injector) What caused that one to tear up most likely has already started to work on the other pistons. You can get 1/4 mm / .010 ths. over-sized pistons from Mahle Motorsports with the correct ring package for Alusil sleeved motors. BB you are most likely to be correct. Those series of Pistons from 01 - 03 have to much Silicone crystals and were brittle, didn't take much detonation to hammer the ring lands.
Cheers _PTEngineering |
#15 |
All my cylinders were at 135-140PSI. It doesn't make sense. None were leaking. Thanks for all your feedback!!!
I was experiencing detonation I believe. So I bet thats it. Now what to do..
__________________
#16 |
Drives: CLK55
How many miles?
__________________
#17 |
91,780
__________________
#18 | |
Drives: Innovation
Quote:
Detonation is the enemy of the motor. You think it was from your tune or a result of something else mechanical? Depends on what you want out of the car |
#19 |
Ya I meant compression. I will try leak down. I think it was because one of my coil packs failed at the same time my MAF did. Would this be the problem?
__________________
#20 |
BlackBenz you were right. Ring ate up walls.
Everything inside the engine is stamped with AMG. I'm gonna take pictures and show you guys. It's pretty cool. A lot of time went into building these AMG's. Gave me a whole different feel for what AMG stands for I'll take pictures when I get a chance. P.S. Those Mahle pistons look expensive..
__________________
AMG Orphans Club International #46 Custom 19X9.5 - 19 X 10.5 on Falken 452's. AMG Emblems (Trunk, Steering Wheel, Hood, Rims) W209 V.2 Intake W209 Engine Mounts Engine Swap/Rebuild More To Come... Last edited by 400HP55; 02-14-2012 at 03:43 AM. |
#21 |
Almost got the engine out. Heres a new pics. Its not to hard but it's just time consuming. I also got my new engine delivered today. It has 70k miles. Will be swapping this weekend!
__________________
#22 |
Drives: CLK55
So it looks like engine comes out the top VS dropping any type of k-member?
I've been curious about this for a while.
__________________
#23 |
Drives: Innovation
__________________
Run your car not your mouth
#24 |
Well, the easiest way is to just to pluck out the engine topside but you have to remove the radiator and all front radiator support, hoses, power steering lines, a/c lines and various other things like wiring harness and such. Thats all you have to remove. And of course the motor mounts. The tricky part is dis-mounting the engine from transmission. More pics...
__________________
#25 |
Old engine out - Then the one wrapped with a orange strap is the the one.
Heres a first start after I did all pre start requirements - no CEL's http://www.youtube.com/watch?v=9-uM5...ature=youtu.be Total Cost - $2800 including new oil, filter, thermostat, intake manifold gaskets, MAF, A/C Charge, power steering fluid, wiring harness swap, motor mount swap, new tensioner pulley, and a few other things. The wiring harness in the old engine didn't swap to the new engine. The alternator grounds were different. Old one was a bolt and the new one is a clip.
__________________
AMG Orphans Club International #46 Custom 19X9.5 - 19 X 10.5 on Falken 452's. AMG Emblems (Trunk, Steering Wheel, Hood, Rims) W209 V.2 Intake W209 Engine Mounts Engine Swap/Rebuild More To Come... Last edited by 400HP55; 03-24-2012 at 12:56 PM. |
| Tags |
| 2001, 63, amg, clk, cly, cylinder, engine, fuel, heads, rail, removal, teardown, top, tune, valves, w208 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
