Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| CLK55 AMG, CLK63 AMG (W208, W209) Discuss the past, present and future CLK55 AMG and the CLK63 AMG. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2001 CLK 55 AMG
help annoying tick..opinions..bearing failure?
#2 |
Drives: '05 C200K SS, '05 Kleemann CLK500K & '92 Z34 5sp (track car in Canada)
Place a finger on each injector and see if one is f'ed up - this was common in our past lives with the DOHC.
__________________
Kleemann S8 CLK500< Kleemann supercharger, cams, headers & tune | H&R springs and sways | Koni adjustable suspension | Brembo GT BBK (6F/4R piston, slotted floating composite rotors) | Carbon fiber front lip & rear diffuser | Custom Magnaflow exhaust, quads with 100 cell cats | GPT pulley | Vorsteiner carbon fiber rear spoiler | Quaife LSD | E55K airbox & kevlar tubes | Magnecor KV85 wires | 360 Straight 5ive wheels, carbon fiber | Mods/build thread |
#3 |
uploaded a vid to a buddies photobucket.
http://s10.photobucket.com/albums/a1...ys%20%20Filez/ some reason it doesn't play sound from the site....probably bc flash was playing it and it is supposed to be played by the devilish quicktime. But when I dled it, it seemed to have sound. Last edited by dohcfiend; 01-17-2012 at 05:09 PM. |
#4 |
okay, definitely not a bad injector.... I dunno dude, hope it's nothing too serious
__________________
#5 |
Drives: CLK55
I don't know... mine makes some of those sounds, I always figured it was an accy ticking.
I'll let you know if mine goes away after fresh oil change this weekend... gonna DIY Oil Change. You can buy an automotive stethoscope that you "carefully" place on diff components while running to isolate the noise. Most of my engine noise comes from my ac comp and ps pump. GL.
__________________
All hail Fleming Kleemann! |
#6 |
ill give it a shot tomorrow. for many months I have been using the vehicle in EC mode. i'll enable the compressor tomorrow and see if there is any notable change.
I will also check my fluid level in my ps pump but it was freshly flushed 4 months ago. I need to Isolate exactly where this tick is coming from. I will also place the mic under the front of the car. but it def sounds like the origin is under the rear section of the engine/beginning section of the transmission.......maybe the off possibility a tq converter has backed itself out a little and hitting block web casting...guess i can remove the shield and take a peek. I just dont know enough yet. I may have ot pay a local mechanic to investigate bc it is just too cold for me to be messing with it for any length of time. |
#7 |
Drives: 03 CLK5.5 AMG
Engine noise
It sound to be a 1/2 engine speed , So I would think you have some valve train lifters that need replacing
![]() Cheers _PTEngineering |
#8 |
that's encouraging. so im guessing the lifter tap is being echoed through the exhaust?
had a mechanic take a quick look and he says it sounds like there is something in the exhaust rattling around.....that's definitely plausible since I had all 4 cats gutted....but not recently. I'll call the guy that did the cats tomorrow and make an appointment to get him to inspect it and cross my fingers that it's just a piece of catalytic material. im not convinced tho....the tick/rattle sounds too consistent to be something jumping around inside the exhaust. Last edited by dohcfiend; 01-18-2012 at 03:32 PM. |
#9 |
think fortune smiles upon me. after using low-tech stethoscope(i.e. 2x2 piece of wood) didn't find any engine noises and traced rattle to resonator.
#10 |
Drives: W209 CLK 55 AMG
I was going to suggest the rattle might be coming from the resonator. My friends 208 AMG made the exact same sound, he replaced the resonator and problem solved!!
__________________
BLACJ on BLACJ |
#11 |
thanks peeps for the informative help! Bullet=dodged...whew!
#12 |
ill post final update when problem resolved..
#13 |
Tickin noise
Just good old mechanicin . Glad to see you used what god gave you. eyes , ears
nose & touch. You developed common sense on your own. Good Show dohcfiend Cheers _PTEngineering |
#14 |
Drives: 2008 CLK63 AMG Black Series
Know you already got it, but for others coming here looking for help, an easy, cheap (might be in your toolbox) stethescope is a screwdriver/long screwdriver, conducts sounds just fine, and of handle to your ear, other end elsewhere. Of course keep away from moving objects, do not test electrical items, that sort of stuff. I do invite others to just try it for fun, on the fuel rail (chattering up a storm), water pump (whooshing away), alternator (if you can reach it) whiny *****, valve cover....we all hope normal soft chatter
. Another ticker for the 320 and 63 motor that I have seen is the canisiter purge solinoid, on the front of the driver's side strut tower, 2003 was first year with these on a CLK, loud as fuk, not sure what years later but on my 2008 it has way more effort done there to mute it, but still loud!! Put your screwdriver on it to isolate this normal sound from any others of concern. Glad you got your rattle found!
__________________
I also drive turbos: 650hp Typhoon, 450hp McLaren TGP, 350hp McLaren TSTE. But the real car is the Black. |
#15 |
Drives: CLK55
Werd on the long-azz screwdriver stethoscope!!!! good call.
__________________
| Tags |
| 2001, amg, clk500, clk55, knock, noise, pump, purge, replace, resonator, tick, ticking, valve, w208, w209, water |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
