My Modding Progress
Old 10-17-2014, 05:44 AM
  #351
suicidal4life's Avatar
2001 E430
Those headers look like a major improvement over the Kleemanns
Old 10-22-2014, 11:31 AM
  #352
blackbenzz's Avatar
haters crazy
Yea they should flow ALOT more
Old 10-31-2014, 05:02 PM
  #353
benzslo's Avatar
C43 5.4, ML320CDI, Fords
damn, those headers are frickin huge.
You're really going at it on this build, I will be curious to see how it runs out. Good luck.
Old 11-26-2014, 03:24 PM
  #354
mercedes430's Avatar
CLK 430
Those headers look amazing! By chance, who did you go through to make them?
Old 11-27-2014, 12:29 AM
  #355
MouTine's Avatar
'14 E500 Coupe
Did you run driver side pipe independently on its own side of transmission? Hows the ground clearance? Been thinking of that since its feels and looks silly when the pipe corners round transmission original route.
Old 01-04-2015, 04:15 PM
  #356
Alex L's Avatar
CLK56TT (WIP), S65, RR 5.0 S/C
Ahmad, did you have your pistons skirts coated with iron by any chance?
Old 01-07-2015, 11:28 AM
  #357
blackbenzz's Avatar
haters crazy
I didn't have a good experience with them so I do not want to promote them
Yes driver side is independent and doe snot crossover. Ground clearace is about the same as before if not better since the v band were removed.
Teflon coated skirts
Old 01-07-2015, 12:46 PM
  #358
blackbenzz's Avatar
haters crazy
And a quick update while I'm here...
Old rod:
New custom Carrillo rod:
And the comparison of stock W211 E55 vs my new custom setup:
Old 01-07-2015, 05:53 PM
  #359
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
The Fins are bending rods on Turbo Diesel 603, 606.
I am glad to see that Carillo jumped in and helped to make right.
Carillo, Kieth Black, Wiesco, Childs and Alberts and a few other forgers will make it to specification.
Been around for many moons.
Thanks for the photo of the rod it is like the early days of nitrous. Bending a rod is better than loosing a block. You have to give the Benz folks some credit.
All the Best, Gator
Old 01-08-2015, 01:35 PM
  #360
blackbenzz's Avatar
haters crazy
All the Best, Gator
Yea but unfortunately the rod didn't just bend, it broke and took out the block with it. Carrillo was $$$
Old 01-08-2015, 08:21 PM
  #361
Alex L's Avatar
Do you mind sharing the cost and maybe the p/n for the rods? PM if possible as in the market for a set, just undecided if I want custom or off the shelf parts.
Also what shells did you use with them and are the rods lighter or heavier that the stocks ones?
Old 01-09-2015, 03:29 AM
  #362
MouTine's Avatar
'14 E500 Coupe
Did the same thing. Funny how much diffirence it made to exhaust note to delete few 90-degree bends. Rest of the exhaust is same no mods.
Old 01-09-2015, 10:54 AM
  #363
blackbenzz's Avatar
haters crazy
I don't know of any aftermarket company that has rods on their shelves for these cars. Everything is custom. Therefore there is no part number. Cost as a little over $3k retail. I can get the exact number but I don't have it off the top of my head. Not cheap and takes approximately 2 months to make. I would sell everything I have but don't want to piece it out.
What shells did I use? Not sure I understand that question. They are heavier than stock rods but much much stronger. Was told they would hold over 1500hp easy
I thought it was just me. It sounded alot smoother but I didn't get may miles on the setup
Old 01-09-2015, 11:28 AM
  #364
Alex L's Avatar
That's fine, I have a local manufacturer (same leadtime), just thought Carillo were standard parts.
Shell = conrod shells.
What's up, you're changing the platform?
Old 01-09-2015, 12:59 PM
  #365
blackbenzz's Avatar
haters crazy
Ok sounds good. Carrillo is one of the top manufacturers of rods. They have standard parts available for some cars but as I said I don't think anybody stocks rods for our cars. All custom made.
Shells must be british terminology. Do you mean bearings? If so, I've heard fo peeople using Honda ones but I'm using the overpriced AMG ones
Just looking for a way out of this money pit
Old 01-09-2015, 05:40 PM
  #366
AMGSC's Avatar
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
Haven't been here for months but still subscribed to your posts and following your progress. Keep pushing the envelope on this platform. It is inspiring.
Old 01-17-2015, 07:51 PM
  #367
GatorMB's Avatar
Yea the rod is Fubar but most break @ I beam under the piston or on top of the crank.
The 603 diesels are twisting, worst case taking out a valve and cylinder which are sleeved.
I mentioned in some of my posts that a creative parts man that races could probably come up with a stronger counterpart that serves the purpose. I used honda rods in the Chevy but Benz and Chevy are no comparison at all.
Hunch Mitsubishi are pumping 1000 hp from a 4cyl. hmmm!!, takes a clever parts search.
Most manufacturers are engineering to comply with life of the engine, The Rod pictured above was part of breaking records and served an admirable life but breaking records with a Benz will cost because of the rarity of the need.
Arias was a dominant forger as well.
If we change any weight of a part in the reciprocating parts of the bottom end balancing is a must.
Go BB,
Gator
Old 01-18-2015, 02:22 AM
  #368
E55 Prototype's Avatar
03 RS6
Gator
At that level they just use really thick aluminum rods and clearance the block
Old 04-03-2015, 11:58 AM
  #369
blackbenzz's Avatar
haters crazy
Thanks I appreciate that I don't frequent the boards as often as I used to either
Go BB,
Gator
Yea everything was balanced.
Old 04-03-2015, 12:21 PM
  #370
blackbenzz's Avatar
haters crazy
And here are some updates.
I flew down to Orlando to pick up/assemble my short block a couple weeks ago.
Precious cargo on the long drive back to MD!
Now to get the car back in the ship from it's resting place for what seems like forever I used my other CLK lol
Time to put the rest of it together! All in the details!
New hybrid oil pump, new chain guides, new everything!
Decided to powdercoat my spare valve covers and install an oil catch can
Everybody likes a good insertion pic
Oh and I picked up this thing and started modding it because I was getting bored waiting for parts for the CLK
Old 04-03-2015, 06:19 PM
  #371
FFXF1's Avatar
2003 Chevy Tahoe
OK Ahmad - I'll bite. What is it??
Old 04-04-2015, 11:59 AM
  #372
2MCHCAR's Avatar
Supercharged CLK500 & ML500
Very nice Build-****!
Old 04-06-2015, 10:00 AM
  #373
blackbenzz's Avatar
haters crazy
The new car? A slow one with warranty lol. 2015 Audi S5
Thanks!
Old 04-09-2015, 05:10 PM
  #374
GatorMB's Avatar
Who did your engine machining in Orlando? I had pretty good relationship with many of the race shop machinists, Bo Laws used to cater to circle track and drag folks. Engine entrepreneur Rick Mann was recruited by Petty Enterprises back in the late 80s and Brother Ray recruited by Bo from RHS Tennessee to port cylinder heads in the 80s.
He died in a car fire after his 69 impala became airborn on the 408 returning home from a speedworld turkey trot drag fest.
His brodix aluminum big block nova is still a masterpiece.
I used in the past Boyd racing, Auto Machine and the moore foundry for custom axles.
Looks like a real winner from the latest photos and more reliable for many runs.
Cheers to BB,
Gator
Old 05-29-2015, 10:46 AM
  #375
blackbenzz's Avatar
haters crazy
Chris took care of my block machining.
I haven't updated this in a while. I went to MIR and Jerry sent me files remotely to try and tune the car. Something was up with the suspension/alignment because the outside of my tires weren't contacting the ground and I couldn't get traction. Best trap of the day was 143.5mph and best ET was 10.007 on the last pass. The car makes enough power to run mid/high 9s with traction and the tune isnt even optimized yet. I haven't touched the car since the track day. Been too busy with the new house. Hopefully run 9s next time out
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
Quick Reply: My Modding Progress
