Sign in using an external account
| CLK55 AMG, CLK63 AMG (W208, W209) Discuss the past, present and future CLK55 AMG and the CLK63 AMG. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2002 CLK 430
Traction Control Light on while on highway?
#2 |
Drives: 2004 CLK 55
I would guess that your tire sizes are different diamaters front to back. I had the same problem with my previous corvette.
#3 |
They are different widths (9 vs 9.5) and the manufacturer for the front/rear is different. If that's all it is, then thank you!! Still a bit concerned as to how/why that would happen though?
#4 |
I have found that if the car skips over an expansion joint or an irregular surface, I get a flash on traction....same thing happens w/GLK...nothing to worry about unless it's coming on when surface is smooth.
__________________
2010 GLK350 4Matic Paladium Silver 2002 black CLK 55,Lorinser roof spoiler, illuminated AMG door sills, Eurocommand by Steve, black birdseye maple shift ****/door handles/arm rest, quad exhaust
#5 |
Drives: 2002 CLK430
Post the name of the tire manufacturers and what tire sizes you're running - then someone can look up the revs per mile figures and tell you for sure.
#6 |
Drives: 05 CLK55 AMG
Sounds like the outer front is spinning a tiny bit faster than the inner rear around the turn and ESP/ABS doesn't appreciate it. I think I read (somewhere?) that up to 4% difference is acceptable.
| Tags |
| 430, benz, blinking, clk, control, highway, lig, light, lights, mercedes, size, tire, traction, turning, w209 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
