W 208 leaking heater core with by pass plz help
AMG CLK55, 450 SEL (sorely missed), Holden Commodore SS, Nissan Navara (company car)
When you had your car at MB, did they hook up a diagnostics machine to check for error codes?
You said "I think there is no water really circulating thru my engine block". Is your engine overheating?
If you grab your engine fan blades, can you move them forwards and backwards a lot?
The greater at the door
When you pull up put the work order as I want to make sure it's not over heating so the re wired the two fans on the out side in know my car the oil cooler gets so hot before the car is even warm that it burns me
What do you mean
Forwards and back wards like spin them or pull on them you said its electrical is there a way the wires are bad connection ? I have wis I jus don't know how to install it and I m waiting on a windows lap top
On the connection can you tell me where to look
