P0106 After Rough longer than usual start
Today I started my car after work and the cel came up after connecting my scanner code P0106 Code Showed "Manifold Absolute Preassure/Barometric Pressure sensor.
Car runs perfectly fine and with power, only with the cel light.
I have'd erased the code before (150 miles) hoping with was something simple cause the car runs so fine, But it has appeared now I'm seeking for answers/help.
Haven't changed the air filter since I bought the car a pretty long time a go can this be the probable cause? I really do not know..
I think you have a bad Map sensor, #: "005 153 50 28" or "006 153 13 28"..
Attachment 292833
ZAYED,,
Attachment 292833
ZAYED,,
Are map sensor's a common component that fails over time?
check codes here
https://mbworld.org/forums/clk-class...ist-codes.html
could just be a bad ground
http://www.obd-codes.com/p0106
check codes here
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit
