CD Magazine Stuck
CD Magazine Stuck
The unit seems to have power, the eject button is lit up green. I press eject, it flashes, makes a noise like it wants to eject, but it doesn't eject.
Surely others have had a similar problem. Its the stock unit in the trunk of my 01 CLK55
Worth a shot. I also noticed that when I press CD on the head unit, it says NO CD CHANGER but maybe that's because there's no disc in there? I'll unplug it and see what I can get it to do.
Fixed it! Not sure how long it will last though. I deliberately dropped it about 8 inches on a flat surface, and it worked again. Instantly ejected using the correct method (the eject button)
I also intentionally broke it again. It seems that switching back from one CD to another one not in sequence immediately was what jammed it up. So going from CD 4 to 1 to 6, relatively fast etc, no good.. "Fixed" it again by dropping it a few inches, and sure enough it ejected again. No problems since putting it back together. Eventually I'll just put a GPS navigation unit in, and find an adapter to use the stock bose system
CLK55 Cabrio, Honda Accord 05 had CLK430 Cabrio
