W208 CLK55 front bushings, two types?
Whats the diffirence between A2083300075 and A2083300175? Cannot find any aswer by browsing the web. Any info here? Thanks.
Kiitos. I actually figured this out when I googeled even more. And parts guy from Bald.de verifyed this allso during ordering.
Still wondering what is the real diffirence... As far as I know both types should be fullfilled with rubber material. Normal C series bushings are filled only with three contact points and all the no-name aftermarket bushings are allso made this way.
2002 CLK 55 AMG cabriolet Eurocharged
I have read in other posts that the stiffer bushings are for cabriolets, The cabs need it to offset frame tweak and extra weight.
A208 refers to the W208 chassis, A is for all part numbers. It is questionable about the part fitting a W209.
