FS: Morello 3 Slate Starless Carbon Grille
Pretty much brand new. I painted the mesh black and started sanding down the edge on both sides in order to fit in the original holes. Still requires a bit more sanding to fit perfect or you can use double sided tape to tape it down right away. The installation requires double sided tape anyways, to hold the bottom from moving up and down due to high speed of wind when driving, since there is no clips/hooks like the OEM version. Has not been driven with, only being test fitted. Reason for selling does not really go with the flow of my car. Asking $270 shipped.
