rear diff.
Old 11-28-2015, 12:05 PM
gixxerboy's Avatar
2013 CLS63, 2001 ML430, 2012 e350 coupe
rear diff.
i'm building an 05 clk55 rear diff for my 09' 550. I want the higher gear ratio. I'm looking to put in a lsd first. Weistec doesn't have one. Is my only option a quafie for your cars?
Old 11-28-2015, 04:14 PM
Tex5's Avatar
CLK 63 AMG Black Series, A45 AMG
Strange, because the CLK 55 rear diff housing is the same as CLK 63 and SLK 55. CLK/SLK 55 have 3.06 final gear where CLK 63 is 2.65. You can put the Wavetrac in it and Weistec sell it for the CLK 63, C 63 etc.
A freind of mine ordered a Wevatrac from Weistec and installed it in the housing of his SLK 55 (same as CLK 55)
You can also use a Drexler LSD, but it is a little more expensive
Old 11-28-2015, 07:06 PM
gixxerboy's Avatar
thats strange because weistec emailed me saying the dont have one that would fit it.
looking on the drexler site i dont see one listed for a w209 either.
Old 11-29-2015, 06:11 PM
Tex5's Avatar
I can assure you the Wavetrac sold by Weistec for CLK or C63 is compatible with the rear diff housing of a CLK/SLK 55 (A2033508564). A friend of mine installed one on his SLK 55. It was initially ordered for my CLK 63, but I changed my mind
You can verify on the wavetrac web site 215 AXLE Applications
Rod from Weistec must be able to confirm
Old 11-29-2015, 06:30 PM
gixxerboy's Avatar
I'll try an contacting them again.
This is the response when i emailed about the wavetrac:
Zach (Weistec Engineering)
Nov 11, 10:03 AM
Hello Chris,
Thank you for your email and interest in Weistec products. Unfortunately, at this time we do not offer any products for your vehicle, except for an TCU upgrade to improve transmission performance and a set of high flow air filers for better air flow.
Please let me know if you would like more information on these products or if you have any questions or concerns. Thank you and we look forward to hearing from you.
Best Regards,
Zach Elmished – Weistec staff
Old 11-29-2015, 06:59 PM
Tex5's Avatar
I am not surprised. I told Rod from Weistec, that The Wavetarc they sold me for my CLK 63 fitted perrfectly in a SLK 55.
Wavetrac only has one LSD for C63, SLK/CLK 55/63. The only différence is the final gear of the rear diff between SLK/CLK 55 (3.06),CLK 63 (2.65) and C63 (2.82)
You have 2.82 strandard on your CLK 550 ?
Will you change the final gear to 3.06 ?
If yes, you probaly already know, but you have to mod your TCU
Old 11-29-2015, 07:04 PM
gixxerboy's Avatar
mine actually has the 2.65 also. Yes in going to keep the 3.06 ratio that is the reason im doing the swap. Kleemann is going to mod the tcu for me.
Old 11-29-2015, 07:10 PM
Tex5's Avatar
You can go for Wavetrac.
Drexler is also a solution. It is OEM lsd of the CLK Black Series
Old 11-29-2015, 07:16 PM
gixxerboy's Avatar
thanks, ill contact someone else at weistec
Old 11-30-2015, 11:40 PM
kb24forlife24's Avatar
None for now
Can't wait for the results and pics/videos
Old 12-07-2015, 10:30 AM
blackbenzz's Avatar
haters crazy
I wonder if the diff I have would bolt up to your car. 3.06 gears and wvaetrac already installed, you would just have to bolt it in. Do you have any pics of your diff? More importantly the mounting points?
Old 12-07-2015, 02:02 PM
gixxerboy's Avatar
I can get pictures later today. What is yours out off?
Old 12-07-2015, 06:18 PM
gixxerboy's Avatar
Here is pics of my diff.
Attached Thumbnails rear diff.-20151207_171043.jpg   rear diff.-20151207_171131.jpg
Old 12-07-2015, 06:31 PM
blackbenzz's Avatar
haters crazy
SRT8. They look very similar but you would have to use your rear cover. I will let you know if I decide to part it out
Quick Reply: rear diff.
