W209 CLK55 M113k build thread
#76
added wires for SC clutch? ECU ja instrument cluster needed to code together? Ok... I got the picture... Thanks.
#79
The engine is from a e55. It came with the engine harness. Just the engine computer needs to be codes.
#81
Ghostrider (11-07-2016)
#85
1 Post
SL500 (R129), C32 AMG (S203)
Okay guys, a little update. My fuel pressure was a little low. The stock system runs 65 psi. The m113k needs atleast 80. After trying different things, this is what worked for me. I used a 6.0 bar internal fpr filter from a 2010 vw gti. It was a direct swap in and it works perfectly.
#89
hello, I'm swapping a clk55amg into a 55amg kompressor M113K I'm bored with two sam connectors before I saw that you had the same problem I took the liberty of writing to you because today I'm not find no wiring getting me out of this
