Passenger Heated Seat not Working
2004 CLK320
Hi All,
I have gone over and over the sight and tried read everything I can on the heated seats. I checked the fuse, checked the wiring for breaks. Now I am on to the wire plugs to check resistance in the seat heating element. (Drivers side works and switch lights up but passenger doesnt). The issue is I cant tell which plug and wires to test for resistance to see if the element is bad.
Does anyone know which plug and wires to test?
(W209 '04 CLK Cab)
(W209 '04 CLK Cab)
This thread contains both of my heated seat problems and some advice. Hope it helps.
https://mbworld.org/forums/clk-class...d-working.html
2004 CLK320
You guys are awesome. The pictures and link helped. I wound up taking out the seat and instantly found the broken wires from the back of the plug(the one which connects from the seat wires)
2004 CLK320
Quick follow up...Before I put the seat back in I tested resistance and it was good 2.4ohms so I knew the element was good. Also make sure to raise the seat to the highest position before unbolting seat or unplugging the connectors!
