CLK63 (non-BS) tire size question
Old 01-25-2016, 08:23 PM
BlueClk63's Avatar
2019 C63s, 2021 E63s Estate
Looking to upgrade the wheels on my 07 CLK63 cab. Does anyone know what the max width I can run in the front/rear on a 19" wheel is without rubbing? I was looking at doing a 275 in the rear on a 9.5/10" wheel but I don't know if the clearance is there and don't have the car in front of me to check.
TIA!
Old 01-26-2016, 05:38 AM
Tex5's Avatar
CLK 63 AMG Black Series, A45 AMG
On mine I have 265/30/19 on rear (9.5/19) and 235/35/19 on front (8.5/19) and there is really few space available, but I have KW competion set up so the car is lower than a stock CLK 63
Old 01-26-2016, 08:27 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
Id like to mention that it is important list the tire make and model as they all fit a little differently.
Old 01-26-2016, 12:15 PM
Tex5's Avatar
Mines are Michelin Pilot Super Sport
Old 02-27-2016, 01:58 PM
gixxerboy's Avatar
2013 CLS63, 2001 ML430, 2012 e350 coupe
i have 18 inch 63 wheels on mine, h&r springs so it sits a little lower and have 275/35 on back and 245/40 on front
Old 02-27-2016, 05:34 PM
2MCHCAR's Avatar
Supercharged CLK500 & ML500
My setup is 19"x8.5 front and 19"x9.5 Rear, total et25 on both (Wheel et35 + 10mm spacer) with 235/35/19 and 275/30/19 Michelin Pilot Super Sports.
With this setup, I had rubbing issues in the rear which I detailed how I dealt with it here:
https://mbworld.org/forums/clk-class...ml#post4833614
I still have a very slight rub in the front, at the plastic wheel cover between the headlight and the front wheel (plus, the tire comes VERY close to my Bilstein HD struts). Not a deal-breaker, but not ideal. When I replace my front tires, I will go with Michelin Pilot Super Sports (again) with the size of 235/30/19. This will shorten the height of the tire by 11.75mm (or by ~.5"), which will take care of the rubbing I described.
Old 02-28-2016, 04:04 PM
gixxerboy's Avatar
Just put on 285/35/18 nitto 555r drag redial
Old 05-20-2016, 11:36 AM
germanAMGmember's Avatar
CLK63 ///AMG w209 , CLS63 ///AMG w219 , CLK500 w209 , CLK320 w208
bigger tires
I have 265 at rear and 235 at fron sizes all in 19"
Regards Frank
Attached Thumbnails CLK63 (non-BS) tire size question-aa2.jpg   CLK63 (non-BS) tire size question-aa.jpg
Old 06-27-2018, 12:39 PM
DecGaPimp's Avatar
CLK63
I have toyo 888r 275/35/18 radials on mine and I get rub around the outside edge of tire on launch. Did you have to make any modifications to get the 285 to clear? How many miles do you usually get on that tire?
Old 05-26-2022, 06:26 AM
michobebe's Avatar
W220 S500 2003 4Matic & W140 1998 S600 V12
what Offset are you running on your rear wheels?
Quick Reply: CLK63 (non-BS) tire size question
