Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > CLK55 AMG, CLK63 AMG (W208, W209) > CLK63 Black Series Forum & Registry
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
CLK63 Black Series Forum & Registry Information and discussion on the W209 CLK63 AMG Black Series and Registry for all owners.
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 01-02-2012, 04:26 AM   #1
badbenzz's Avatar
Drives: CLK63bs, FX50S,VROD
Battery Help
Where's the battery....purchased car last Thursday went out of the country for 8 days and the car did not start. Called MB to start the car and the technician could not even tell me where the battery is located. How do you guys tickle charge your car, I used the one for my Porsche and it does not work since the cig. lighter goes dead when the call is shut off.
To remove this ad, register today or login if you already are registered!
badbenzz is offline   Reply With Quote
Old 01-02-2012, 05:56 AM   #2
Drives: 2008 BS
It is underneath where the rear seats would normally be.
ecampbell is offline   Reply With Quote
Old 01-02-2012, 10:48 AM   #3
LOVEMYBS's Avatar
Drives: 09 ML550, 07 Porsche 911 Turbo
Quote:
You're correct, the cigarette lighter type trickle charger will not work. I bought an MB trickle charger that connects directly to the existing battery port-like connector located in the upper left rear drivers side trunk, behind the removable cover panel. It's easily installed and all I have to do is unplug the AC cord. The charger stays attached to the battery port and remains in the trunk. It couldn't be easier and my battery is always charged. Check with MB parts, if I recall it was about $100.00 and well worth it!
__________________
2010 Porsche Cayenne GTS Design Edition 3 #261.
07 Porsche 997 TT/Black/Black/Tiptronic/MPSS's
06 BMW X3 3.0i Bluewater/Tan/Wife's
Sold
09 ML550 4Matic/Iridium Silver/Black
08 CLK63 AMG Black Series/Iridium Silver/Black (sad)
07 CLK63 AMG Cabriolet/Iridium Silver/Black
07 E550 4Matic/Sport/P2
07 SL55 AMG w/030
06 SL55 AMG w/030 (Totaled)
05 E55 AMG
04 CLK55 AMG
LOVEMYBS is offline   Reply With Quote
Old 01-02-2012, 01:09 PM   #4
badbenzz's Avatar
Thanks Love I will look into it.
Old 01-03-2012, 12:10 AM   #5
badbenzz's Avatar
Thanks hooked up the tender today. Battery is located under the rear panel in the center.
Old 01-04-2012, 12:13 PM   #6
RBYCC's Avatar
Drives: 88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
No need to access the interior battery compartment to use a battery tender.
There is a charge/jump point in the left side of the engine compartment near the shock towers.
Just flip up the red lid and you will see a connection point that accepts an alligator clip for the positive side of the battery.
Secure the negative to a common ground point not far from the covered positive point.
I use a $19.00 Schumacher SEM-1562A 1.5 Amp Speed Charge Maintainer connected to this point in the winter months.
As "LovemyBS" previously posted there is also a charging point in the trunk that accepts the OEM MB charger.
__________________
TURBOTECHNICS TWIN TURBO M103 300CE WIDEBODY
1971 280SL
1988 300CE TT
1994 E320 CABRIOLET
1999 C43 AMG
2005 G55K AMG
2008 CLK63 BLACK SERIES AMG
RBYCC is offline   Reply With Quote
Old 01-04-2012, 12:23 PM   #7
badbenzz's Avatar
Thanks RBYCC the tender is currently installd with a pig tail hanging off the rear compartment for easy access. However, dragging the wires thru the window every time is not the most effective way to do it. Do you just shut the trunk on the wire when you use the MB version?
Old 01-04-2012, 08:37 PM   #8
LOVEMYBS's Avatar
Yes, I shut the trunk on the AC cord, no problem. When I'm ready to go I unplug the AC cord and store it in the trunk. I like simple solutions!
__________________
Sold
07 SL55 AMG w/030
05 E55 AMG
04 CLK55 AMG
Old 01-04-2012, 11:02 PM   #9
Drives: CLK 63 AMG Black
The only "not simple" part of the MB trunk-insertion point charger is that fitting the male end of the charger into the female end of the trunk port is a finger breaker. And, just as hard to undo. So, once you plug the male end into the female end, best thing is to just leave the entire unit in the trunk, including the power cord. I leave it that way for winter, but really cannot for track days. AS
alexander stemer is offline   Reply With Quote
Old 01-04-2012, 11:14 PM   #10
RBYCC's Avatar
I don't use the MB charger and trunk charging point.
I just leave my hood open and connect to the charging point in the engine bay.
__________________
1971 280SL
1988 300CE TT
1994 E320 CABRIOLET
1999 C43 AMG
2005 G55K AMG
Old 01-04-2012, 11:26 PM   #11
Drives: CLK63 BS
Quote:
Is it that hard to take on and off? lol. Was thinking about ordering one of the MB ones cause it sounds easy.
fatmike is offline   Reply With Quote
Old 01-05-2012, 08:40 AM   #12
LOVEMYBS's Avatar
I don't recall it being difficult but that was over two years ago. Now that's its installed it just stays in the trunk until needed.
__________________
Sold
07 SL55 AMG w/030
05 E55 AMG
04 CLK55 AMG
Tags
911, 99, amg, battery, black, c63, charger, cigarette, clk63, iridium, location, porsche, series, silver, work
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
