Build the most powerful cls550 4matic
Rating: Thread Rating: 2 votes, 5.00 average.
Old 09-04-2016, 10:57 PM
  #51
scflaw's Avatar
W218 CLS 400, F20 M135
I'd like to ask whats the best way to seperate the IC Coolant from the engine coolant and how is the additional IC pump connected? Thanks
Old 09-10-2016, 04:57 PM
  #52
cocobeex's Avatar
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
Any update on this ?
Interested to know if the AMG fuel pump will fix the issue.
Old 09-10-2016, 06:00 PM
  #53
gardevski's Avatar
cls63 amg pp 700hp, ml63 amg w166 700hp, cls550 4matic 720hp
When i removed my stock pumps to replace them with the AMG pumps i found that my pump was weak and almost dead.
After installing the AMG fuel pump i discovered that AMG fuel pump controller is also needed as the AMG pump is using different three phase motor than the stock 550 pump. After installing the controller (finger crossed) the car will be completed and will report back.
Meanwhile the final mod that i made and the last to ever made on that car was installed (652x450x26mm) intercooler heat exchanger. It works with the stock one also installed and both are more than enough to keep the IAT as low as possible (paired with CWA 100.2 pump) all the time even on many hard accelerations. It's not thick and do not block the main radiator stream.
Old 09-21-2016, 03:33 AM
  #54
cocobeex's Avatar
If your original pump is almost dead, maybe all you need is another original pump ??
Btw, how's the progress ?
Old 09-24-2016, 07:56 AM
  #55
gardevski's Avatar
Hello,
I have retrofited the AMG fuel pumps with success. Used the original Fuel pump controller but rearrange the wires to be able to run the pump. No more fuel pressure drops under any load. Will schedule dyno session in the next 10 days to see the final result. The car is very very fast 0-200km/h under 10 sek.
Old 10-15-2016, 01:05 PM
  #56
mJstk01's Avatar
Hello,
Any luck on dyno??
Old 10-15-2016, 04:54 PM
  #57
darealtalent's Avatar
cls63
Update
Old 10-25-2016, 09:27 AM
  #58
mJstk01's Avatar
Originally Posted by mJstk01
Any luck on dyno??
checking in...
Old 11-10-2016, 01:31 AM
  #59
gardevski's Avatar
Hi All,
My car is complete. The car feature the following:
M157 turbochargers
Intrcooler system upgrade (pump and very big heat exchanger)
1 step Colder Spark plugs
k&N air filters
Custom turbo-back downpipes
3 inch full exhaust
100 cell racing cats
Custom ECU Tune
AMG Fuel pump
AMG front and back calipers/rotors
amg body kit (better for cooling the engine), new Diamond White Pearl
4matic with quaife Limited Slip Differential
Power: 723hp 1222N/m on 93 gas
To have an idea for the result. Yesterday we had dyno session with all our cars: Ml63 amg 2013, CLS63 amg 2013 PP and my cls 500 4matic. The ML63 made 691hp and 1250n/m, CLS63 AMG PP 699hp and 1380n/m (it has full 3 inch exhaust from HMS, carbon ceramic brakes..) and my CLS500 723 and 1222n/m. Same day, same tunner, same dyno.
Facebook Post
JeanPierPapin (12-28-2020)
Old 11-10-2016, 06:27 AM
  #60
gaiex's Avatar
'08 CLK320CDI AMG// '13 E500 Coupe AMG// '17 E350d AMG
Impressive!!!
Did you do anything to the CLS550 gearbox?
Old 11-10-2016, 10:14 AM
  #61
Dueclaws's Avatar
'12 E550C, Sierra Denali
Good job Gardevski!
Old 11-10-2016, 01:13 PM
  #62
TTMerc's Avatar
2014 CLS63 S
Glad everything came together! Awesome Results!! Do you have any graphs? Id like to see the powerband difference from the M157!! M278 having a bit more compression should be quite a little monster!
Old 11-11-2016, 04:50 PM
  #63
gardevski's Avatar
Originally Posted by gaiex
Impressive!!!
No. The gearbox is stock and it's performance is more than great. At this power levels i didnt see any difference in gear changes compared to my cls63 amg 2013. Is has same speed and response, very quick when you step on it.
Old 11-11-2016, 04:58 PM
  #64
gardevski's Avatar
Yes. I already requested my dyno sheet to be send be email by my tuner. It was a long day with all three cars and i forgot to take the sheets.. Will post it as soon as i have it
Old 11-11-2016, 04:59 PM
  #65
gardevski's Avatar
Originally Posted by Dueclaws
Good job Gardevski!
Thank you!
Old 11-11-2016, 05:02 PM
  #66
cocobeex's Avatar
Wow!!! That's awesome!!!
Is it stock m157 turbo ?
No mod on the m157 turbo ? Just with ECU tune ??
Old 11-11-2016, 05:16 PM
  #67
gardevski's Avatar
Yes. Stock m157 turbochargers with no upgrades on them No matter m157 or m278 engine, the turbos are the limit of the engine. With upgraded m157 turbos m278 will go well over 800hp..
Old 11-11-2016, 06:19 PM
  #68
cocobeex's Avatar
I have got a pair m157 waiting to be installed.
I'll wait for Weistec, as I know they are developing the tune for modded m157 turbo, for m278 engines.
Old 11-11-2016, 07:09 PM
  #69
mJstk01's Avatar
Did they announce this somewhere?
Old 11-11-2016, 07:49 PM
  #70
cocobeex's Avatar
Their engineers are still testing the tune.
Why would they announce it when its not finished ?
You can call them and ask.
Old 11-12-2016, 05:38 AM
  #71
gardevski's Avatar
I was about to also mod the turbos before the installation in my car. The issue i see with this engine is the higher compression ratio. The M278 is 10.5:1 and the car is about to knock if not tuned right. With high flow turbochargers it need a lot less compression ratio. My car with the stock m157 turbochargers is flawless. Will post dyno sheet later today.
Also the 4matic's front axles are on their limit with 1200+ n/m torque as our cars are 45/55 front/back (for example the amg s 4matic is 33/67-percent front-to-rear torque split The front axles are 1/2 the diameter of the rear...
Old 11-12-2016, 03:53 PM
  #72
mJstk01's Avatar
Companies commonly announce upcoming products in development for marketing purposes...
Old 11-12-2016, 04:02 PM
  #73
mJstk01's Avatar
Great build and results!!!
Do you have any plan on offering a package thru your company in the future or was this a one-off build?
Old 11-13-2016, 05:44 AM
  #74
cocobeex's Avatar
I really have no idea why they keeps it secretly.
But as I checked with them, it is in progress.
Like I said, call them and find out.
There are 2 options for me.
1. Just install stock m157 turbo on, and do a ECU tune, like what OP did.
2. Wait till Weistec finish their project (They said around Mid December 2016). But I have a feeling, there will be a lot of things needs to be upgraded at same time.
That is amazing what you have done there.
I might just go with the same mod.
Might be cheaper this way than having turbo modded.
Turbo modded = lot more thing might also need upgrades, such as transmission and axles.
I do have a question about the fuel pump.
Was your original fuel pump nearly dead ? or does it really need an AMG pump in order to supply enough fuel to the engine ? (The tune need more fuel ?)
Someone told me original fuel pump should be sufficient. Thats why I am asking.
Old 11-15-2016, 11:16 AM
  #75
gardevski's Avatar
Hi All,
Please find attached the long waited dyno sheet of my CLS500 4matic
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: Build the most powerful cls550 4matic
