19" wheels tire fittment
Old 01-02-2017, 02:58 PM
CLS 6.3's Avatar
12 CLS 500
Im tired of the 20" wheels that came with my 2012 cls 550
With the ****ty roads we have 20" is not an option for a daily driver
I just bought a set of 19",, 8.5" front and 9.5" rear and im wondering what is the maximum rubber that i can fit with no rubbing issues
Currently considering the
245/40/19 front 275/35/19 rear
Will this set up fit with rubbing,,if not what do you guys recommend?
Old 01-02-2017, 09:35 PM
SpeedRacerX's Avatar
2012 CLS550 4Matic
Need to know your wheel offsets in order to answer your question.
Old 02-09-2017, 03:52 PM
CLS 6.3's Avatar
12 CLS 500
Wheels finally arrived
And here is the offset
Rear 19x9.5 offset 35
Front 19x8.5 offset 35
Would this setup fit
245/40/19 front
275/35/19 rear
Old 02-09-2017, 04:20 PM
threeMBs's Avatar
Only MBs - the best or nothing
245/40/19 front
275/35/19 rear
Yes this set up will fit, however due to higher front diameter than stock with stock front offset, 5mm to 10mm front spacers are advised. For the rear, assuming you're not lowered, you can use even 285/35-19.
Old 02-09-2017, 07:38 PM
CLS 6.3's Avatar
12 CLS 500
I appreciate your fast response,,and yes im not lowered
just to be sure,,if i run the set up without the spacers there may be a chance of rubbing in the front?
Old 02-09-2017, 08:37 PM
threeMBs's Avatar
245/40-19 tire is about 26.7" diameter (vs. stock's 26") combined with stock like 35mm front offset will be very close to airmatic's rubber boot. You should be OK, but just in case you're not, 5mm or 10mm hub centric spacers (absolutely safe to use) with longer bolts will do the job.
Old 02-10-2017, 08:25 PM
2012 CLS550 4Matic
threeMBs covered it.
I know it's all personal preference, who likes the flush look, etc, etc but I wished you had gone with an offset for the rear in the 40-50 range as it would have given you more options for a stock or wider tire for the rear. Also, if profile is the same ratio and all else equal, a wider tire would also give you a slightly larger side wall for a hair extra cushion to help with those potholes.
That rear offset makes matching a wide front and rear staggered set challenging due to rub with the rear lip, trying to match all 4 tires heights, etc.
Let us know what you decide and how it turns out.
Old 02-11-2017, 04:23 PM
CLS 6.3's Avatar
12 CLS 500
Thank you again for your clarification your info are very helpful and i will update you guys of how everything turns out,,the car still at the shop recovering from the **** the 20" wheels has done to it.
Replaced
Ball joints
Control arms( upper and lower)
Tie rods(steering rack)
And last but not least front passenger side airmatic shock is gone and being serviced now
Once all done ill post some pics and details for how everything turned out
Old 02-15-2017, 07:29 PM
CLS 6.3's Avatar
12 CLS 500
I appreciate all the help and support you guys shown through the process and here is how everything turned out.
I went with a set of hankook tires with no spacers in front to try it out,,I experienced no rubbing,,I can feel the ride quality got better over bumps not as stiff as oem
245/40/19 front
285/35/19 rear
I have included pics of clearance of front tires and how it looks with its new shoes
Attached Thumbnails 19" wheels tire fittment-img_0964.jpg   19" wheels tire fittment-img_0966.jpg   19" wheels tire fittment-img_0968.jpg
Old 06-10-2017, 01:12 PM
weisenheimer's Avatar
BMW E46
Hi guys -
does it mean that i can install
8.5 et35
9.5 et35
245/40/19 front
285/35/19 rear
without rubbing?
Old 07-20-2017, 04:40 PM
12cls550's Avatar
2012 CLS550
Are you selling your 20" rims? If so, send some pics.
Old 07-20-2017, 04:42 PM
Jan AMG's Avatar
The best or nothing
Hi, why are you not sticking to original approved sizes?
Quick Reply: 19" wheels tire fittment
