1st error message at 4,100 miles
Airbus
SRS Red light and Restraint system malfunction message "Drive to Workshop"
The last time I had a SRS malfunction in another car,they had to tear the seat apart and replace a sensor. Taking it in this Sat morning. Hope it is a quick fix.
Received 4,417 Likes
'71 Pinto
Originally Posted by MDCLS
SRS Red light and Restraint system malfunction message "Drive to Workshop" Hope it is a quick fix.
Airbus
Mention P-B-91.60/99a JAN06 – SRS Light Illuminated. Airbag line to steering column module needs replacement (SCM).
Repair Airbag Harness to SCM. 2.6 Hours.
ST Test .3 Hour.
As per P-B--91.60/99A
Short Test Found Code 9123 in AB
Airbag Line to Steering Column Replaced/Repaired.
Also had a problem with rear pass door closing correctly. (closed with a window rattle) All it says is "parts have been special ordered."
