Go Back   MBWorld.org Forums > Mercedes-Benz Coupes & Cabriolets > CLS Coupe (C219)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
CLS Coupe (C219) Discuss the CLS Coupe.
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-11-2012, 08:18 AM   #1
suf
Drives: mercedes cls 320 d
DPF BLOCKED
hi
urgent helped required please -
CLS 320d 2055 model -
dealer had the car at the weekend as EML light was on - advised DPF is blocked so a manual regeneration was needed - dealer tried this and still showing blocked -
advised a replacement DPF is needed.
option -
buy new DPF £1800
steam clean DPF
Remove dpf and remap ECU.
your advise would be appreciated
To remove this ad, register today or login if you already are registered!
suf is offline   Reply With Quote
Old 04-11-2012, 03:24 PM   #2
RobertG's Avatar
Drives: things with and without wheels
why did the DPF get blocked, if you buy a new one and it gets blocked too would be a waste.
maybe its just the sensor that reads blocked?
What kind of driving do you do (a lot of stop and go)?
You cant steam clean the DPF inside, that gets done using a special machine that bakes it and then blows air through it.
RobertG is offline   Reply With Quote
Old 04-11-2012, 03:50 PM   #3
suf
DPF sensor Was changed by dealer in July 11.
I do motorway driving 50 miles a day.
Not sure if it is going to be steam cleaned but the garage cleans DPF filters on merc sprinter vans.
Dealer said it is totally blocked as car is in limp mode fulltime
I have spoken to a software company who can remove filter and update software for £400
Old 04-12-2012, 12:47 PM   #4
Drives: 2006 CLS500
What is a DPF?
rbrtclk is offline   Reply With Quote
Old 04-12-2012, 01:13 PM   #5
konigstiger's Avatar
Drives: '71 Pinto
Quote:
Originally Posted by rbrtclk View Post
What is a DPF?
Diesel Particle Filter
__________________
konigstiger is offline   Reply With Quote
Old 04-12-2012, 07:05 PM   #6
Drives: 2006 CLS500
Thanks, makes all the sense in the world to me. The illustration was great. I guess that's why I do not see Black Smoke coming from Mercedes diesels anymore.
Old 04-13-2012, 08:28 AM   #7
RobertG's Avatar
there is a delta sensor that compares pressures as well as individual sensors that read pressures at the inlet and outlet, mercedes might call them a different name,but they all work the same way.
Driving in a stop and go traffic will do the most trouble in getting it sooted up,it needs to get up to temperature and stay there for the soot to burn off.
What is the fuel quality that you are using and are you using any additives?
What kind of engine oil are you using, it has to be low ash engine oil.
Engine oil in the exhaust is also a well known culprit in taking out the DPFs .
I dont know the emission laws in your neck of the woods, but removing and bypassing the dpfs sound cheaper then replacing it with a new one.
Old 07-04-2012, 06:35 AM   #8
peko's Avatar
Drives: w204 220cdi amg
hi friends
i'm loocking for info to regeneration DPF filter please ?
i clean DPF but can't erase DTC, so i think car need regenration
anybody know procedure to erase this dtc using xentry
thank you
peko is offline   Reply With Quote
Tags
benz, clean, cleaning, diesel, dpf, ecu, filter, limp, mercedes, mode, regeneration, removal, reset, sprinter, steam, w169
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
