CLS Coupe (C219) Discuss the CLS Coupe.
CLS 500 DIY Oil & Filter change
Old 07-11-2012, 12:47 PM
BrianFrancis's Avatar
CLS 500
I want to change the oil, oil filter, and air filters on my CLS 500 myself. I checked some of the older posts, however they seem to contradict one another. There was a post that said that there wasn't a drain plug at all, and the oil had to be vaccumed out. I checked another and it was said that there were two drain plugs. Does anyone know for sure?
Also, I need to know how many quarts of oil to add after the change if it is a DIY project, and the best oil to replace it with. The owners manual doesn't give me anything on this.
Someone was talking about AMSOIL, and how good it is. I wanted to ask before going that route. If anyone has any info, let me know.
Thinking of going with the K&N air filters, but I need to know how to remove the engine cover to get to them. If anyone can help, I certainly would appreciate it.
Old 07-11-2012, 10:08 PM
rbrtclk's Avatar
2006 CLS500
The CLS 500 takes eight quarts of oil for a oil and filter change. I use Mobil 1 5w 40. It's a full synthetic. There is one drain plug but you have to remove the under pan to see it. That's why if you take it to a dealer he will just suck all the old oil out through the dipstick. You can purchase a dipstick like the ones the dealer uses to check the quantity of oil. To replace the air filters, you pull up on the front engine cover then pull up on the big part that is left. The big cover is held on by clips that grab little rubber mounts and pulls right off. Turn the big cover over and you will see where the two filters are. Each one is held in by four #25 Torx screws . Remove the screws and replace tha filters.
Old 07-12-2012, 08:21 AM
CLS 500
Rbrt, I certainly thank you for the help. This forum is awesome!!! I never thought I would be able to get this kind of help so quickly. Kudos to whoever started this site!!!!
Old 07-13-2012, 07:03 AM
motorking's Avatar
cadillac cts-v
oil change
Hi,
I am the technical manager at FRAM filters.
Here is the info on what oil is approved by Mercedes for your vehicle. It holds 8 qts when the filter is changed. Mightyvac makes the tool used to pull oil out through the dipstick. If you plan to do oil changes yourself, it is worth investing in.
MB-Approved Sythetic Engine Oil
Mobil 1 0w-40
Mobil 1 Formula M 5w-40
Castrol Syntec European Formula* 0w-30
Pennzoil Platinum European Formula Ultra* 5w-30
ELF Excellium 229.5* 5w-30
Mobil 1 ESP Formula M*++ (Diesel only) 5w-40
Valvoline Synpower MST*++ (Diesel only) 5w-30
ELF Solaris LSX*++ (Diesel only) 5w-30
++As of model year 2007 diesel engines must only use 229.51 approved engine oil
229.51 is only approved for diesel engines
*Not approved for use in AMG engines
229.5 or 229.51 engine oils must be used in conjunctions with fleece oil filter in vehicles with Mercedes-Benz Maintenance System (as of MY2005). Using other oil filters may lead to engine damage which is not covered by the Mercedes-Benz Limited Warranty.
MB Sheet numbers are printed on the outside of oil containers
Approved engine oil viscosity in relation to temperature
Below -13°F/-25°C to Above +86°F/+30°C 0W-30, 0W-40.
Above -13°F/-25°C to Above +86°F/+30°C 5W-30, 5W-40, 5W-50
Above -4°F/-20°C to Above +86°F/+30°C 10W-30, 10W-40, 10W-50, 10W-60
Above +5°F/-15°C to Above +86°F/+30°C 15W-30, 15W-40, 15W-50
Above +23°F/-5°C to Above +86°F/+30°C 20W-40, 20W-50
We make a made in USA 15k oil filter for these cars, the part number is XG8481. Good luck with your oil change and if you have any other oil or filter related questions, happy to answer at jay.buckley@framgrp.com
Old 07-14-2012, 11:01 AM
TexasMEC's Avatar
CLS 550 Mec Design
Great info, thanks for posting it.
Old 05-16-2013, 07:50 PM
alliedtooth's Avatar
2009 CLS550, 2011ML350 bluetec
Originally Posted by motorking
Hi,
Mobil 1 0w-40
Jay , many thanks for the quick reply via email. I think you may have saved my engine from damage. The guys at my local parts store sold me the wrong filter and if it weren't for Jay , I would have installed a filter not designed for synthetic oil.
Alex
Old 07-17-2014, 11:28 AM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
Can someone list the steps on how to check the oil level from the steering wheel controls??? 2008 cls500 or post a snippet from the manual?
Old 07-17-2014, 11:52 AM
konigstiger's Avatar
Received 4,414 Likes on 3,144 Posts
'71 Pinto
How about dipstick...
File Type: pdf
Old 07-17-2014, 01:18 PM
Jason B's Avatar
Thanks but the 2008 CLS doesn't have a dip stick. It has a small thing that pulls out that is 1" long only...
see here, strange, but there is no dipstick:
http://www.justanswer.com/mercedes/7...oil-level.html - and I can't get to the screen they are talking about in the display.
Old 10-09-2014, 05:46 PM
timmahhhh's Avatar
2009 CLS, 2005 JETTA TDI WAGON
Mightyvac is worth the money for changing oil on German cars with top mounted filters. Lets you do the whole job from the top, and saves a lot of headaches.
Quick Reply: CLS 500 DIY Oil & Filter change
