CLS Coupe (C219) Discuss the CLS Coupe.
TPMS QUESTION
Old 07-25-2013, 06:29 PM
CLSED550's Avatar
CLS, Grand Cherokee, Range Rover HSE, 70 cuda 440+6
TPMS QUESTION
If I take my stock wheels off car with original sensors and I decide to put a different set of wheels on the car with the same frequency sensor does it have to be program, Or can I just reset on the dashboard And it will automatically detect the new but same style sensors.
2008 CLS550 , I picked up a set of tpms sensors used.
Any feedback about this would be appreciated
Old 07-25-2013, 06:33 PM
Former Vendor of MBWorld
Need4Speed's Avatar
2018 C63S
The sensors do have to be programmed to your vehicle, or you can even re-use your stock sensors.
Hope this helps
Old 07-25-2013, 06:52 PM
CLSED550's Avatar
Thanks , maybe I will break the bead on stock tire/wheel and use those. I have a guy at tire shop and he said he can reprogram, I guess I will see what is cheaper to do. Either way it will work.
Thanks for the information.
Old 07-25-2013, 07:20 PM
Need4Speed's Avatar
2018 C63S
No problem, I hope you get it all figured out!
Old 07-26-2013, 09:29 AM
TitanTPMS's Avatar
TITANTPMS
What is the part number from the used TPMS you picked up. I can check and see if it what you need for your 2008 CLS550. The Mhz or frequency is just one part of the equation. If the part number is the same all you should have to do is drive and the sensors will LEARN automatically.
Here is how to Relearn New Sensor Ids.
Ensure all tires are inflated to the pressure listed on the tire placard. Vehicle must be driven for at least 10 minutes, while maintaining speed above 15 mph in order for system to learn new sensor IDs. If spare tire sensor ID is being programmed, a properly formatted scan tool is necessary.
Old 07-26-2013, 07:31 PM
mschamberger's Avatar
2014 CLS550
I have two sets of wheels - 1 set for winter & 1 set for summer. I swap my wheels out twice a year and simply reset the TPMS using the driver info center (nothing done to the individual sensors) and I'm good to go. Soooo much easier than resetting the TPMS on my Vette.
Old 07-26-2013, 11:24 PM
jaedee's Avatar
w205 C63s, w212 E63,w219CLS500-SOLD! w211 E63, 2006 E60 M5 (KABOOM!)
Ditto for my 63
Old 07-28-2013, 03:25 PM
CLSED550's Avatar
Here is a photo of the extra sensors I have for my 2008 CLS550 .
Also I was told I have to change the outer nut that hold the sensor on the wheel? They are $16 each, just the nut, don't look like there are any seals in it.
Let me know... Thanks guys
Old 07-29-2013, 11:52 AM
TitanTPMS's Avatar
TITANTPMS
Here is a list of what that sensor part number will fit. You will need to replace the HEX nut and gromit (the rubber) for all tire service. $16 per nut is craziness. I can do much better than that in price. Give me a call we can get you taken care of.
2007 CLK45 AMG
2007-2009 GL320
2007-2009 GL450
2008-2009 GL550
2007-2009 ML320
2006-2009 ML350
2006-2007 ML500
2008-2009 ML550
2007-2009 ML63 AMG
2007-2009 R320
2006-2009 R350
2006-2007 R500
2007 R63 AMG
2009 S450
2010 S63 AMG
Old 07-29-2013, 11:57 AM
TitanTPMS's Avatar
TITANTPMS
Need a set of TPMS for the Winter-Summer or even track tires we can get you taken care of! Titan TPMS has blank sensors that we can CLONE Id's into no resetting or relearning needs to be done. Quick and easy!!! W/FREE SHIPPING
Old 07-31-2013, 07:02 AM
CLSED550's Avatar
2007 CLK45 AMG
2007-2009 GL320
2007-2009 GL450
2008-2009 GL550
2007-2009 ML320
2006-2009 ML350
2006-2007 ML500
2008-2009 ML550
2007-2009 ML63 AMG
2007-2009 R320
2006-2009 R350
2006-2007 R500
2007 R63 AMG
2009 S450
2010 S63 AMG
I called and they tried to sell me sensors.. ? Titan told me they only have valves for there after market sensors, if this is a mistake email me @ indy1141@gmail.com or reply to this post.
I was going to install the old valves, the rubber looked good on the inside and the outer nuts have no seal in it.
1 more thing, i am using OE sensors i purchased a few moths back, will my car learn the new sensors by just driving ? I have the sensors in my trunk right now (0psi) and they weren't detected by car after driving for 20mins. Dash reads " No TPMS Sensors Dectected".
When i put them in the Wheel will they then read or do i need a diagnostic computer to program ?
Not sure if the sensors need pressure to send signal, with them not instaled in wheels ; car is not comunicating with sensors as of now.
**(these are not my orignal sensors, this is a mercedes sensor from same model car, photo in above posts.)
Old 07-31-2013, 06:41 PM
95viper's Avatar
2007 cls550
I really need to know the answer to this too.
Old 08-01-2013, 11:58 AM
swiftvision's Avatar
NSX
My 06 does NOT have TPMS sensors in the wheels (I guess it's in the hub???).
The shop just swapped my wheels with aftermarket with no parts brought over.
Old 08-01-2013, 06:24 PM
CLSED550's Avatar
Your correct, an 06 has a sensor located internally, not the wheels. 2007-up measures pressure, a 2006 measures rotating diameter and when the diameter changes beyond its perimeters it sets off an dash alert.
Old 08-03-2014, 09:13 AM
Justin9212's Avatar
2000 ML430 / 2001 CLK55 AMG / 2007 R320 CDI / 2005 S55 AMG / 2001 ML55 AMG / 2006 C55 AMG
Tire sensors go to sleep when they are not spinning in a wheel. So just setting them in your trunk will not wake them up to be learned.
Quick Reply: TPMS QUESTION
